28755| 22
[常见问题] 用arduino作AVR ISP——烧bootloader |
本帖最后由 touchfree 于 2016-4-29 15:08 编辑 thk god,发帖不易! 因为有两块arduino板子,我们把作为ISP烧录器的arduino板子成为板A,丢了bootloader的arduino板子叫板B。(注:本贴中板A仅支持arduino的ATmega168 / 328 芯片,就是UNO,Mega,Leonardo不支持 ) (如何用Leonardo做ISP 烧写器,请访问英文论坛图文教程链接:Using Leonardo as the ISP programmer) 好了我们开始: 1 打开ArduinoISP样例代码; 注:对于Arduino 1.0, 要对程序做些修改:找到 heartbeat() 子函数,把"delay(40);" 改成 "delay(20);" 2 将板A和电脑连接上,选好板A对应的型号、串口号,把ArduinoISP样例上传; 3 连线; 注:① 板A如果是Arduino Uno,需在reset和GND之间加一个10μF的电容(电解电容有+-极,长脚接reset,短脚接GND); ② 板B如果是Uno、Bluno可按图1连线,如果是其他类型板子如:Romeo,MEGA2560等,则需对应ICSP的对应管脚关系连线,参照图2 图1 图2 找到对应管脚很重要,后期error很可能卡在这里! 4 选好板B对应的型号,选择 Programmer > Arduino as ISP command. 5点击Burn Bootloader,静等……done! bling~ling! |
大神知道一下 问啥 引导程序也烧录不进去 Arduino:1.6.10 (Windows 7), 开发板:"Arduino/Genuino Uno" 构建选项已变更,全部重新构建 项目使用了 4,380 字节,占用了 (13%) 程序存储空间。最大为 32,256 字节。 全局变量使用了481字节,(23%)的动态内存,余留1,567字节局部变量。最大为2,048字节。 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x96 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x96 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x96 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x96 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x96 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x96 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x96 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x96 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x96 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x96 上传出错。查看http://www.arduino.cc/en/Guide/Troubleshooting#upload 获取建议。 在文件 -> 首选项开启 “编译过程中显示详细输出”选项 这份报告会包含更多信息。 |
为什么我弄很多遍还是出现avrdude: stk500_getsync(): not in sync: resp=0xff |
刚试了一下,代码里是不是要把#define RESET SS 改为 #define RESET 10 Burn bootloader前要把board改为板B的版型 |
