19532| 13
[原创教程] 【树莓派教程】——树莓派摄像头使用 |
![]() ![]() 参数: 镜头:1/4 5M 光圈:2.9 焦距:3.29 视场角:72.4度 硬件连接: 1. 软排线,90度垂直连接器,HDMI口旁边那个。连接时触点一侧朝向HDMI接口。 ![]() 2. 使用前撕掉镜头上的保护膜 3. 裸板,注意ESD伤害,谨防静电! 树莓派设置-启用摄像头 1.命令行开启 ![]() ![]() ![]() ![]() 2.界面开启 ![]() ![]() 树莓派摄像头模块同时支持1代Model A、Model B、Model B+、2代B型 版本的树莓派,该模块的感光芯片采用的是OmniVision公司生产的1/4英寸OV5647芯片,可通过软排线直接与树莓派控制板连接。它配备500万像素的图像传感器,能录制每秒30帧(不卡顿)的1080p全高清视频,或拍摄2592x1944分辨率的图片,而且您也可以把树莓派安装在您的小车上,通过无线网络制作无线监控小车。也可以应用图像识别和图像追踪,创意无限,精彩就在动脑一瞬间,来吧! 软件使用: 1. RPi固件和raspi-config已经为了摄像头更新,请执行一次apt-get update; apt-get upgrade; 2. raspi-config中选择camera,启动RPi固件中的摄像头驱动,然后重启 3. 使用命令行程序raspivid和raspistill操作摄像头,捕捉视频片段或图像 4. 捕捉到的视频片段需要用mplayer播放 命令调用摄像头: # 获取一张照片并发送至标准输出设备,显示20s
![]() 常用命令: # 两秒钟(时间单位为毫秒)延迟后拍摄一张照片,并保存为 image.jpg
Sensor type: OmniVision OV5647 Color CMOS QSXGA (5-megapixel) Sensor size: 3.67 x 2.74 mm (1/4" format) Pixel Count: 2592 x 1944 Pixel Size: 1.4 x 1.4 um Lens: f=3.6 mm, f/2.9 The angle of View: 54 x 41 degrees Field of View: 2.0 x 1.33 at 2 m Full-frame SLR lens equivalent: 35 mm Fixed Focus: 1 m to infinity Video: 1080p at 30 fps with codec H.264 (AVC) Up to 90 fps Video at VGA Board size: 25 x 24 mm (not including flex cable) Because the focal length of the lens is roughly the same as the width of the sensor, it is easy to remember the field of view: at x meters away, you can see about x meters horizontally, assuming 4x3 stills mode. Horizontal field of view in 1080p video mode is 75% of that (75% H x 55% V sensor crop for 1:1 pixels at 1920x1080). References: Focal length and f-stop measurements, depth of field & angle of view calculators sensor info f-stop measurement |
