5526| 0
[项目] 如何用树莓派的命令行播放视频 |
如果你想播放视频文件,但同时你又不想安装一个类似XBMC这样的完整的视频播放软件,那么你可以在命令行下直接通过Omxplayer来播放视频。这个媒体播放器由Edgar Hucek专门为树莓派编写的,并针对树莓派的GPU进行了优化。 安装 Omxplayer已经打包在了最新的树莓派安装镜像里,所以你可能已经安装好了。如果你没有安装,你可以用以下命令进行安装: [mw_shl_code=applescript,true] sudo apt-get update sudo apt-get -y install omxplayer[/mw_shl_code] 基本用法 想要播放一个视频文件,你只需要在命令行里输入: [mw_shl_code=applescript,true] omxplayer myvideo.mp4[/mw_shl_code] 如果你正在使用HDMI接口,那么,你需要用以下命令将音频传递到HDMI接口: [mw_shl_code=applescript,true]omxplayer -o hdmi myvideo.mp4[/mw_shl_code] 其它一些命令行选项 如果你输入: cmxplayer 将会显示出各种变量选项的列表: Usage: omxplayer [OPTIONS] [FILE] Options : [mw_shl_code=applescript,true]-h / –help print this help -n / –aidx index audio stream index : e.g. 1 -o / –adev device audio out device : e.g. hdmi/local -i / –info dump stream format and exit -s / –stats pts and buffer stats -p / –passthrough audio passthrough -d / –deinterlace deinterlacing -w / –hw hw audio decoding -3 / –3d mode switch tv into 3d mode (e.g. SBS/TB) -y / –hdmiclocksync adjust display refresh rate to match video (default) -z / –nohdmiclocksync do not adjust display refresh rate to match video -t / –sid index show subtitle with index -r / –refresh adjust framerate/resolution to video -l / –pos start position (in seconds) –boost-on-downmix boost volume when downmixing –subtitles path external subtitles in UTF-8 srt form at –font path subtitle font (default: /usr/share/fonts/truetype/freefont/FreeSans.ttf) –font-size size font size as thousandths of screen height (default: 55) –align left/center subtitle alignment (default: left) –lines n number of lines to accommodate in the subtitle buffer (default: 3) [/mw_shl_code] 键盘的快捷键 这里列举出了一些键盘的快捷,可以用它们来控制视频的播放: [mw_shl_code=applescript,true]Space or p Pause/Resume q Exit OMXPlayer z Show Info - Decrease Volume + Increase Volume i Previous Chapter o Next Chapter Left Arrow Seek -30 Right Arrow Seek +30 Down Arrow Seek -600 Up Arrow Seek +600 1 Increase Speed 2 Decrease Speed j Previous Audio stream k Next Audio stream n Previous Subtitle stream m Next Subtitle stream s Toggle subtitles d Subtitle delay -250 ms f Subtitle delay +250 ms[/mw_shl_code] 如果你已经通过树莓派的相机模块拍摄了一些视频,并且希望用过命令行进行回放,那么Omxplayer会非常有用。 原文链接: Matt |
