7750| 4
[求助] 求助!求助!请大神赐教ardunio遥控蜂鸣器播放音乐的用法 |
4 创造力 | 回复本帖可获得 2 创造力奖励! 每人限 1 次 |
随便写的,你可以试试 [mw_shl_code=applescript,true]#include <IRremote.h> #include <ctype.h> #include <Wire.h> IRrecv __ab_irrecv(11); void __ab_setupIrReceiver() { __ab_irrecv.enableIRIn(); __ab_irrecv.resume(); } void charsToUpper(char *str) { int p=0; while(str[p] != 0) { str[p] = toupper(str[p]); ++p; } } void __ab_getIrCommand(char *receivedCommand) { decode_results result; if (__ab_irrecv.decode(&result)) { ltoa(result.value, receivedCommand, 16); charsToUpper(receivedCommand); __ab_irrecv.resume(); } else { receivedCommand[0] = '\0'; } } char _ABVAR_1_ircode[64] = ""; void setup() { __ab_setupIrReceiver(); } void newtone(int tonePin,int frequency, int duration) { pinMode(tonePin,OUTPUT); int period = 1000000 / frequency; int pulse = period / 2; for (long i = 0; i < duration * 1000; i += period) { digitalWrite(tonePin, HIGH); delayMicroseconds(pulse); digitalWrite(tonePin, LOW); delayMicroseconds(pulse); } } void loop() { __ab_getIrCommand(_ABVAR_1_ircode); if (!( strlen(_ABVAR_1_ircode) == 0 )) { if (strcmp(_ABVAR_1_ircode, "FF30CF") == 0) //FF30CF 为遥控器按键的编码 { newtone(8,440, 1000); } if (strcmp(_ABVAR_1_ircode, "FF18E7") == 0) { newtone(8,1000, 1000); } } delay( 1000 ); }[/mw_shl_code] |
