7002| 0
[uPyCraft IDE] uPyCraft-micropython教程(dfrobot MQTT实现双向控制) |
此实验代码有些问题,楼主调整中,请先不要测试 此实验紧接着单向控制实现,在做本实验之前,请阅读玩MQTT单向控制章节 准备工作: 硬件平台: FireBeetle-ESP32 x2 IO扩展板 x1 Button模块 x1 软件平台: uPyCraft-V0.21 物联网网站:https://iot.dfrobot.com.cn 本实验实现的效果 设备A订阅TOPIC_LEDA,设备B按键后向这个设备A发送toggle消息,让LEDA状态反转 设备B订阅TOPIC_LEDB,设备A定时向设备B发送on off消息,控制LEDB状态 从而实现双向控制 开始干活: 第一步,第二步,第三步:和上次实验相同,申请两个TOPIC,一个LED_A,一个LED_B 第四步: 设备A执行下面代码[mw_shl_code=python,true]from umqtt.simple import MQTTClient from machine import Pin,Timer import network import time SSID="DFROBOT_AP" PASSWORD="12345678" led=Pin(2, Pin.OUT, value=0) tim = Timer(-1) SERVER = "182.254.130.180" CLIENT_ID = "S1grx_VmNW1" TOPIC = b"B1rl_47NZ" username='H1UGxqD4-' password='BkeLGeqvVb' stateA = 0 stateB = 0 def sub_cb(topic, msg): global state print((topic, msg)) if msg == b"on": led.value(0) stateA = 0 print("1") elif msg == b"off": led.value(1) stateA = 1 print("0") elif msg == b"toggle": # LED is inversed, so setting it to current state # value will make it toggle led.value(stateA) stateA = 1 - stateA def connectWifi(ssid,passwd): global wlan wlan=network.WLAN(network.STA_IF) wlan.active(True) wlan.disconnect() wlan.connect(ssid,passwd) while(wlan.ifconfig()[0]=='0.0.0.0'): time.sleep(1) def timerOnOff(t): global stateB,c if(stateB == 1): c.publish(TOPIC_LEDB, b'on') stateB = 0 else: c.publish(TOPIC_LEDB, b'off') stateB = 1 connectWifi(SSID,PASSWORD) server=SERVER c = MQTTClient(CLIENT_ID, server,0,username,password) c.set_callback(sub_cb) c.connect() c.subscribe(TOPIC) print("Connected to %s, subscribed to %s topic" % (server, TOPIC)) tim.init(period=3000, mode=Timer.PERIODIC, callback=timerOnOff) try: while 1: c.wait_msg() finally: c.disconnect() tim.deinit() [/mw_shl_code] 设备B执行下面代码 [mw_shl_code=python,true]from umqtt.simple import MQTTClient from machine import Pin,Timer import network import time SSID="DFROBOT_AP" PASSWORD="12345678" SERVER = "182.254.130.180" CLIENT_ID = "S1grx_VmNW2" TOPIC_LEDA = b"B1rl_47NZ" TOPIC_LEDB = b'S1LowEX4b' username='H1UGxqD4-' password='BkeLGeqvVb' stateA = 0 stateB = 0 def sub_cb(topic, msg): global state print((topic, msg)) if msg == b"on": led.value(0) stateB = 0 print("1") elif msg == b"off": led.value(1) stateB = 1 print("0") elif msg == b"toggle": # LED is inversed, so setting it to current state # value will make it toggle led.value(stateB) stateB = 1 - stateB def buttonFunc(v): global c time.sleep_ms(50) if(button.value() == 0): return while(button.value() == 1): time.sleep_ms(100) time.sleep_ms(100) c.publish(TOPIC_LEDA,b'toggle') def connectWifi(ssid,passwd): global wlan wlan=network.WLAN(network.STA_IF) wlan.active(True) wlan.disconnect() wlan.connect(ssid,passwd) while(wlan.ifconfig()[0]=='0.0.0.0'): time.sleep(1) connectWifi(SSID,PASSWORD) server=SERVER c = MQTTClient(CLIENT_ID, server,0,username,password) c.set_callback(sub_cb) c.connect() c.subscribe(TOPIC) print("Connected to %s, subscribed to %s topic" % (server, TOPIC_LEDB)) button = Pin(25, Pin.IN) button.irq(trigger=Pin.IRQ_RISING, handler=buttonFunc try: while 1: c.wait_msg() finally: c.disconnect() [/mw_shl_code] 第五步:设备A执行代码,设备B执行代码,与预期结果相同 |
