5481| 1
[教程] Raspi-config 命令行 |
本帖最后由 吹口琴的钢铁侠 于 2017-8-24 16:37 编辑 稍微多用过树莓派的朋友相信都用过raspi-config这个工具,通过它可以相对可视化的容易地改变树莓派的配置。 在这个代码里面可以看到一些细节。 很多命令都是成对出现的,比如和hostname相关的
设置启用I2C可以通过[mw_shl_code=bash,true]raspi-config nonint get_i2c 0[/mw_shl_code],0表示开启,1表示关闭(不同的命令可能是不同的对应)。 [mw_shl_code=c,true]/* Command strings */ #define GET_CAN_EXPAND "raspi-config nonint get_can_expand" #define EXPAND_FS "raspi-config nonint do_expand_rootfs" #define GET_HOSTNAME "raspi-config nonint get_hostname" #define SET_HOSTNAME "raspi-config nonint do_hostname %s" #define GET_BOOT_CLI "raspi-config nonint get_boot_cli" #define GET_AUTOLOGIN "raspi-config nonint get_autologin" #define SET_BOOT_CLI "raspi-config nonint do_boot_behaviour B1" #define SET_BOOT_CLIA "raspi-config nonint do_boot_behaviour B2" #define SET_BOOT_GUI "raspi-config nonint do_boot_behaviour B3" #define SET_BOOT_GUIA "raspi-config nonint do_boot_behaviour B4" #define GET_BOOT_WAIT "raspi-config nonint get_boot_wait" #define SET_BOOT_WAIT "raspi-config nonint do_boot_wait %d" #define GET_SPLASH "raspi-config nonint get_boot_splash" #define SET_SPLASH "raspi-config nonint do_boot_splash %d" #define GET_OVERSCAN "raspi-config nonint get_overscan" #define SET_OVERSCAN "raspi-config nonint do_overscan %d" #define GET_CAMERA "raspi-config nonint get_camera" #define SET_CAMERA "raspi-config nonint do_camera %d" #define GET_SSH "raspi-config nonint get_ssh" #define SET_SSH "raspi-config nonint do_ssh %d" #define GET_VNC "raspi-config nonint get_vnc" #define SET_VNC "raspi-config nonint do_vnc %d" #define GET_SPI "raspi-config nonint get_spi" #define SET_SPI "raspi-config nonint do_spi %d" #define GET_I2C "raspi-config nonint get_i2c" #define SET_I2C "raspi-config nonint do_i2c %d" #define GET_SERIAL "raspi-config nonint get_serial" #define GET_SERIALHW "raspi-config nonint get_serial_hw" #define SET_SERIAL "raspi-config nonint do_serial %d" #define GET_1WIRE "raspi-config nonint get_onewire" #define SET_1WIRE "raspi-config nonint do_onewire %d" #define GET_RGPIO "raspi-config nonint get_rgpio" #define SET_RGPIO "raspi-config nonint do_rgpio %d" #define GET_PI_TYPE "raspi-config nonint get_pi_type" #define GET_OVERCLOCK "raspi-config nonint get_config_var arm_freq /boot/config.txt" #define SET_OVERCLOCK "raspi-config nonint do_overclock %s" #define GET_GPU_MEM "raspi-config nonint get_config_var gpu_mem /boot/config.txt" #define GET_GPU_MEM_256 "raspi-config nonint get_config_var gpu_mem_256 /boot/config.txt" #define GET_GPU_MEM_512 "raspi-config nonint get_config_var gpu_mem_512 /boot/config.txt" #define GET_GPU_MEM_1K "raspi-config nonint get_config_var gpu_mem_1024 /boot/config.txt" #define SET_GPU_MEM "raspi-config nonint do_memory_split %d" #define GET_HDMI_GROUP "raspi-config nonint get_config_var hdmi_group /boot/config.txt" #define GET_HDMI_MODE "raspi-config nonint get_config_var hdmi_mode /boot/config.txt" #define SET_HDMI_GP_MOD "raspi-config nonint do_resolution %d %d" #define GET_WIFI_CTRY "raspi-config nonint get_wifi_country" #define SET_WIFI_CTRY "raspi-config nonint do_wifi_country %s" #define CHANGE_PASSWD "(echo \"%s\" ; echo \"%s\" ; echo \"%s\") | passwd"[/mw_shl_code] |
