6032| 11
[高级教程] 当掌控遇上Blynk(2)——远程控制七彩灯 |
本帖最后由 rzyzzxw 于 2019-1-8 21:08 编辑 [mw_shl_code=python,true]import network,BlynkLib,time from mpython import * wlan = network.WLAN(network.STA_IF) wlan.active(True) if not wlan.isconnected(): print('connecting to network...') wlan.connect('Maker Space', '12345678') #wifi信息 while not wlan.isconnected(): pass print('network config:', wlan.ifconfig())#输出wifi连接信息 BLYNK_AUTH = 'a7bdb2d016d74e839f96660bf******'#Blynk授权码 blynk = BlynkLib.Blynk(BLYNK_AUTH)# 初始化Blynk连接 @blynk.VIRTUAL_WRITE(0) def v0_write_handler(value):#从Blnyk的V0管脚获取到value,value是一个list类型 rgb[0] = (int(value[0]),int(value[1]),int(value[2])) rgb[1] = (int(value[0]),int(value[1]),int(value[2])) rgb[2] = (int(value[0]),int(value[1]),int(value[2])) # 获取到三个颜色值,并从str转成int型 rgb.write() while True: blynk.run()#一直运行blynk pass[/mw_shl_code] |
write file mixly.py... Timeout: Serial has no response! Now retry... ========> done! NOTICE: mixly_tool.py is the same in board, now skip it! NOTICE: BlynkLib.py is the same in board, now skip it! write file mpython.py... ========> done! NOTICE: reset.py is the same in board, now skip it! machine reseting... ========> done! set main.py... ========> done! run program... exec(open('mixly.py').read(),globals()) ___ __ __ / _ )/ /_ _____ / /__ / _ / / // / _ \/ '_/ /____/_/\_, /_//_/_/\_\ /___/ for Python v0.2.0 [0;32mI (2722) phy: phy_version: 3910, c0c45a3, May 21 2018, 18:07:06, 0, 0[0m connecting to network... network config: ('172.19.233.23', '255.255.0.0', '172.19.233.1', '172.19.233.1') Traceback (most recent call last): File "<stdin>", line 1, in <module> File "<string>", line 12, in <module> File "BlynkLib.py", line 211, in __init__ File "BlynkLib.py", line 57, in __init__ TypeError: function takes 2 positional arguments but 1 were given >>> 请问出现了这种问题该怎么修改? |
