7631| 21
[求助] 24路舵机控制板控制MG996r一直转圈圈 |
首先要测试下伺服电机,用下面的代码试下: [mw_shl_code=applescript,true]//Servo Potentiometer Control #include <Servo.h> const int SERVO=9; //Servo on Pin 9 const int POT=0; //POT on Analog Pin 0 Servo myServo; int val = 0; //for storing the reading from the POT void setup() { myServo.attach(SERVO); } void loop() { val = analogRead(POT); //Read Pot val = map(val, 0, 1023, 0, 179); //scale it to servo range myServo.write(val); //sets the servo delay(15); //waits for the servo }[/mw_shl_code] |
