4274| 3
[已解决] arduino报错(Error loading Python DLL: C:\Users\ADMINI~1\AppData\Local\Tem... |
麻烦大神们帮忙解答一下谢谢 下面是错误日志: Arduino:1.8.5 (Windows 7), 开发板:"FireBeetle-ESP32, 80MHz, 921600, None" sketch\Blink.ino.cpp:1:0: warning: -fstack-protector not supported for this target #include <Arduino.h> ^ <command-line>:0:32: warning: ISO C++11 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\esp32-hal-adc.c:1:0: warning: -fstack-protector not supported for this target // Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\esp32-hal-bt.c:1:0: warning: -fstack-protector not supported for this target // Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\esp32-hal-dac.c:1:0: warning: -fstack-protector not supported for this target // Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\esp32-hal-gpio.c:1:0: warning: -fstack-protector not supported for this target // Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\esp32-hal-i2c.c:1:0: warning: -fstack-protector not supported for this target // Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\esp32-hal-ledc.c:1:0: warning: -fstack-protector not supported for this target // Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\esp32-hal-matrix.c:1:0: warning: -fstack-protector not supported for this target // Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\esp32-hal-misc.c:1:0: warning: -fstack-protector not supported for this target // Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\esp32-hal-sigmadelta.c:1:0: warning: -fstack-protector not supported for this target // Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\esp32-hal-spi.c:1:0: warning: -fstack-protector not supported for this target // Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\esp32-hal-time.c:1:0: warning: -fstack-protector not supported for this target // Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\esp32-hal-timer.c:1:0: warning: -fstack-protector not supported for this target // Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\esp32-hal-touch.c:1:0: warning: -fstack-protector not supported for this target // Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\esp32-hal-uart.c:1:0: warning: -fstack-protector not supported for this target // Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\stdlib_noniso.c:1:0: warning: -fstack-protector not supported for this target /* ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\wiring_pulse.c:1:0: warning: -fstack-protector not supported for this target /* ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\wiring_shift.c:1:0: warning: -fstack-protector not supported for this target /* ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\libb64\cdecode.c:1:0: warning: -fstack-protector not supported for this target /* ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\libb64\cencode.c:1:0: warning: -fstack-protector not supported for this target /* ^ <command-line>:0:32: warning: ISO C99 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\Esp.cpp:1:0: warning: -fstack-protector not supported for this target /* ^ <command-line>:0:32: warning: ISO C++11 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\HardwareSerial.cpp:1:0: warning: -fstack-protector not supported for this target #include <stdlib.h> ^ <command-line>:0:32: warning: ISO C++11 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\IPAddress.cpp:1:0: warning: -fstack-protector not supported for this target /* ^ <command-line>:0:32: warning: ISO C++11 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\IPv6Address.cpp:1:0: warning: -fstack-protector not supported for this target /* ^ <command-line>:0:32: warning: ISO C++11 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\MD5Builder.cpp:1:0: warning: -fstack-protector not supported for this target /* ^ <command-line>:0:32: warning: ISO C++11 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\Print.cpp:1:0: warning: -fstack-protector not supported for this target /* ^ <command-line>:0:32: warning: ISO C++11 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\Stream.cpp:1:0: warning: -fstack-protector not supported for this target /* ^ <command-line>:0:32: warning: ISO C++11 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\StreamString.cpp:1:0: warning: -fstack-protector not supported for this target /** ^ <command-line>:0:32: warning: ISO C++11 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\WMath.cpp:1:0: warning: -fstack-protector not supported for this target /* -*- mode: jde; c-basic-offset: 2; indent-tabs-mode: nil -*- */ ^ <command-line>:0:32: warning: ISO C++11 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\WString.cpp:1:0: warning: -fstack-protector not supported for this target /* ^ <command-line>:0:32: warning: ISO C++11 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\base64.cpp:1:0: warning: -fstack-protector not supported for this target /** ^ <command-line>:0:32: warning: ISO C++11 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\cbuf.cpp:1:0: warning: -fstack-protector not supported for this target /* ^ <command-line>:0:32: warning: ISO C++11 requires whitespace after the macro name C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\DFRobot_FireBeetle-ESP32\0.0.9\cores\esp32\main.cpp:1:0: warning: -fstack-protector not supported for this target #include "freertos/FreeRTOS.h" ^ <command-line>:0:32: warning: ISO C++11 requires whitespace after the macro name Error loading Python DLL: C:\Users\ADMINI~1\AppData\Local\Temp\_MEI126682\python27.dll (error code 1006) exit status -1 为开发板 FireBeetle-ESP32 编译时出错。 在文件 -> 首选项开启 “编译过程中显示详细输出”选项 这份报告会包含更多信息。 |
