2451| 0
[uPyCraft IDE] 使用BMP280模块检测压强和温度 |
#http://docs.dfrobot.com.cn/bxy/4.2.16bmp280.html #https://www.dfrobot.com.cn/goods-1860.html #根据BMP280模块获取:温度、压强、海拔 from microbit import * I2C_ADDR = 0x77 class BMP280(): def __init__(self,i2c): self.i2c = i2c self.T1 = self.get2Reg(0x88) self.T2 = self.short(self.get2Reg(0x8A)) self.T3 = self.short(self.get2Reg(0x8C)) self.P1 = self.get2Reg(0x8E) self.P2 = self.short(self.get2Reg(0x90)) self.P3 = self.short(self.get2Reg(0x92)) self.P4 = self.short(self.get2Reg(0x94)) self.P5 = self.short(self.get2Reg(0x96)) self.P6 = self.short(self.get2Reg(0x98)) self.P7 = self.short(self.get2Reg(0x9A)) self.P8 = self.short(self.get2Reg(0x9C)) self.P9 = self.short(self.get2Reg(0x9E)) self.setReg(0xF4, 0x2F) self.setReg(0xF5, 0x0C) self.T = 0 self.P = 0 def short(self, dat): if dat > 32767: return dat-65536 else: return dat def setReg(self,reg,dat): self.i2c.write(I2C_ADDR, bytearray([reg,dat])) def getReg(self,reg): self.i2c.write(I2C_ADDR,bytearray([reg])) t = self.i2c.read(I2C_ADDR,1) return t[0] def get2Reg(self,reg): self.i2c.write(I2C_ADDR,bytearray([reg])) t = self.i2c.read(I2C_ADDR,2) return t[0]+t[1]*256 def get(self): adc_T = (self.getReg(0xFA)<<12) + (self.getReg(0xFB)<<4) + (self.getReg(0xFC)>>4) var1 = (((adc_T>>3)-(self.T1<<1))*self.T2)>>11 var2 = (((((adc_T>>4)-self.T1)*((adc_T>>4) - self.T1))>>12)*self.T3)>>14 t = var1+var2 self.T = ((t * 5 + 128) >> 8)/100 var1 = (t>>1) - 64000 var2 = (((var1>>2) * (var1>>2)) >> 11 ) * self.P6 var2 = var2 + ((var1*self.P5)<<1) var2 = (var2>>2)+(self.P4<<16) var1 = (((self.P3*((var1>>2)*(var1>>2))>>13)>>3) + (((self.P2) * var1)>>1))>>18 var1 = ((32768+var1)*self.P1)>>15 if var1 == 0: return adc_P = (self.getReg(0xF7)<<12) + (self.getReg(0xF8)<<4) + (self.getReg(0xF9)>>4) p=((1048576-adc_P)-(var2>>12))*3125 if p < 0x80000000: p = (p << 1) // var1 else: p = (p // var1) * 2 var1 = (self.P9 * (((p>>3)*(p>>3))>>13))>>12 var2 = (((p>>2)) * self.P8)>>13 self.P = p + ((var1 + var2 + self.P7) >> 4) return [self.T, self.P] def getTemp(self): self.get() return self.T def getPress(self): self.get() return self.P def getAltitude(self): return 44330*(1-(self.getPress()/101325)**(1/5.255)) i2c.init(freq=100000,scl=pin19,sda=pin20) bmp=BMP280(i2c) print(str(bmp.getTemp())+' *C') print(str(bmp.getPress())+' Pa') print(str(bmp.getAltitude())+' m') |
