2953| 1
[进阶] 使用M5StickC/ESP32制作基于web的遥控器 |
本帖最后由 vany5921 于 2019-8-20 20:52 编辑 M5StickC内置了红外发射器,可以通过编写程序发送遥控编码,下面的案例将展示通过M5StickC建立Webserve服务器,手机通过页面操作控制(TOSHIBA/Panasonic)遥控器的编码文件单独进行了封装 [mw_shl_code=c,true]#include <M5StickC.h> #include <WiFi.h> #include <DNSServer.h> #include <WiFiClient.h> #include <WebServer.h> #include <WiFiManager.h> //https://github.com/Brunez3BD/WIFIMANAGER-ESP32 #include <ESPmDNS.h> #include <WiFiClient.h> #include <aJSON.h> //https://github.com/interactive-matter/aJson https://gitlab.com/xarduino/ligh ... on-void-flush.patch #include <IRremote.h> //https://github.com/SensorsIot/Arduino-IRremote WebServer webServer(80); byte SEND_PIN = 9; // IR:9 IRsend irsend(SEND_PIN); void handleIndex(){ Serial.println("handleIndex"); String s = "<html lang=\"en\"><head><meta charset=\"utf-8\"/><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\"><title>M5StickC-IR</title><link rel=\"stylesheet\" href=\"https://cdnjs.cloudflare.com/ajax/libs/twitter-bootstrap/3.3.7/css/bootstrap.min.css\" /><script src=\"https://cdnjs.cloudflare.com/ajax/libs/jquery/3.2.1/jquery.min.js\"></script><script src=\"https://cdnjs.cloudflare.com/ajax/libs/twitter-bootstrap/3.3.7/js/bootstrap.min.js\"></script></head><body><div class=\"container\"><div class=\"row\"><div class=\"col-md-12\"><h1>M5StickC-IR <small>"; //s += localName; s += "m5c"; s += ".local</small></h1><p>IP address: "; s += String(WiFi.localIP()[0]) + "." + String(WiFi.localIP()[1]) + "." + String(WiFi.localIP()[2]) + "." + String(WiFi.localIP()[3]); s += "</p><hr><div class=\"form-group\">"; s += "<textarea class=\"form-control\" id=\"message\" rows=\"10\"></textarea></div>"; s += "<div class=\"row\"> <button class=\"btn btn-success\" id=\"post\">POST</button> "; s += " <button class=\"btn btn-danger\" id=\"LEDON\">LED ON</button> "; s += " <button class=\"btn btn-info\" id=\"LEDOFF\">LED OFF</button>"; //重置无线网络 s += " <button class=\"btn\" id=\"WIFIRESET\">WiFi reset</button> </div>"; s += "</div>"; s += "<script>var xhr = new XMLHttpRequest();var textarea = document.getElementById(\"message\");"; //s += "document.getElementById(\"get\").addEventListener(\"click\", function () {xhr.open('GET', '/messages', true);xhr.setRequestHeader('X-Requested-With', 'curl');xhr.onreadystatechange = function() {if(xhr.readyState == 4) {textarea.value =xhr.responseText;}};xhr.send(null);});"; s += "document.getElementById(\"post\").addEventListener(\"click\", function () {data = textarea.value;xhr.open('POST', '/messages', true);xhr.onreadystatechange = function() {if(xhr.readyState == 4) {alert(xhr.responseText);}};xhr.setRequestHeader('Content-Type', 'application/json');xhr.setRequestHeader('X-Requested-With', 'curl');xhr.send(data);});"; //LED ON s += "document.getElementById(\"LEDON\").addEventListener(\"click\", function () {xhr.open('get', '/ledon', true);xhr.setRequestHeader('X-Requested-With', 'curl');xhr.onreadystatechange = function() {if(xhr.readyState == 4) {textarea.value =xhr.responseText;}};xhr.send(null);});"; //LED OFF s += "document.getElementById(\"LEDOFF\").addEventListener(\"click\", function () {xhr.open('get', '/ledoff', true);xhr.setRequestHeader('X-Requested-With', 'curl');xhr.onreadystatechange = function() {if(xhr.readyState == 4) {textarea.value =xhr.responseText;}};xhr.send(null);});"; //WIFI重置 s += "document.getElementById(\"WIFIRESET\").addEventListener(\"click\", function () {var result=confirm('Reset WiFi settings?');if(result){xhr.open('get', '/wifireset', true);xhr.setRequestHeader('X-Requested-With', 'curl');xhr.onreadystatechange = function() {if(xhr.readyState == 4) {textarea.value =xhr.responseText;}};xhr.send(null);}});"; s += "</script></body></html>"; webServer.send(200, "text/html", s); } void handleNotFound() { Serial.println(webServer.uri().c_str()); Serial.println("404"); webServer.send(404, "text/plain", "Not found."); } void handleMessages() { Serial.println(webServer.uri().c_str()); //add if (webServer.method() == HTTP_POST) { //irrecv.disableIRIn(); // String req = webServer.arg(0); char json[req.length() + 1]; req.toCharArray(json, req.length() + 1); Serial.println(json); // aJsonObject* root = aJson.parse(json); if (root != NULL) { aJsonObject* freq = aJson.getObjectItem(root, "freq"); aJsonObject* data = aJson.getObjectItem(root, "data"); if (freq != NULL && data != NULL) { const uint16_t d_size = aJson.getArraySize(data); //uint16_t rawData[d_size]; unsigned int rawData[d_size]; // for (int i = 0; i < d_size; i++) { aJsonObject* d_int = aJson.getArrayItem(data, i); rawData = d_int->valueint; } irsend.sendRaw(rawData, d_size, (uint16_t)freq->valueint); //irrecv.enableIRIn(); // req = ""; aJson.deleteItem(root); webServer.sendHeader("Access-Control-Allow-Origin", "*"); webServer.send(200, "text/plain", "ok"); } else { webServer.send(400, "text/plain", "Invalid JSON format"); } } else { webServer.send(400, "text/plain", "Request body is empty"); } } } void handleLedOn() { Serial.println("LED ON"); digitalWrite(M5_LED, LOW); //LED ON webServer.send(200, "text/plain", "ok"); } void handleLedOff() { Serial.println("LED OFF"); digitalWrite(M5_LED, HIGH); //LED OFF webServer.send(200, "text/plain", "ok"); } void handleWiFiReset(); // void setup() { // --------------------------------------------------------------- M5.begin(); M5.Lcd.fillScreen(BLACK); M5.Axp.ScreenBreath(9); //7 - 12屏幕亮度 // LED pinMode(M5_LED, OUTPUT); digitalWrite(M5_LED, LOW); //LEDON delay(200); digitalWrite(M5_LED, HIGH); //LEDOFF pinMode(M5_BUTTON_HOME, INPUT); pinMode(M5_BUTTON_RST, INPUT); //start serial connection Serial.begin(115200); Serial.println("\n Starting"); WiFiManager wifiManager; M5.Lcd.setTextSize(1); M5.Lcd.setCursor(5,0); //M5.Lcd.println("AP mode: \r\nAutoConnectAP"); //M5.Lcd.println("IP address: \r\n192.168.4.1"); M5.Lcd.println("M5StickC-IR"); M5.Lcd.println("\nIf you want to setup WiFi, \nPower off, \nPress Button RST \nand Power On!!!"); //M5.Lcd.println("IP address: \r\n192.168.4.1"); //delay(5000); if(digitalRead(M5_BUTTON_RST) == LOW){ //启动时显示提示信息 M5.Lcd.fillScreen(BLACK); //clear M5.Lcd.setTextSize(1); M5.Lcd.setCursor(5,0); M5.Lcd.println("AP mode: \nOnDemandAP"); M5.Lcd.println("\nconnect to WiFi, \nM5StickC-AP"); M5.Lcd.println("\nOpen \n192.168.4.1"); digitalWrite(M5_LED, LOW); //LED ON while(digitalRead(M5_BUTTON_RST) == LOW); digitalWrite(M5_LED, HIGH); //LED OFF for (int i=0; i <= 3; i++){ delay(200); digitalWrite(M5_LED, LOW); //LED ON delay(200); digitalWrite(M5_LED, HIGH); //LED OFF } //启动WiFiManager if (!wifiManager.startConfigPortal("M5StickC-AP")) { Serial.println("failed to connect and hit timeout"); delay(3000); } //reset and try again, or maybe put it to deep sleep ESP.restart(); delay(2000); } else { //wifiManager.autoConnect("M5StickC-AP"); //AutoConnectAP Serial.println("WiFi.begin()"); WiFi.begin(); M5.Lcd.setCursor(5,120); int i = 0; while (WiFi.status() != WL_CONNECTED) { //设定超时时间10秒 if(i > 20){break;} delay(500); i++; Serial.print("."); M5.Lcd.print("."); } Serial.println("!"); M5.Lcd.println("! "); } IPAddress ipadr = WiFi.localIP(); if(WiFi.status() == WL_CONNECTED){ Serial.println("connected.."); M5.Lcd.println("connected.."); Serial.println(WiFi.SSID()); } else { Serial.println("not connected!!!"); M5.Lcd.println("not connected!!!"); } delay(1000); M5.Lcd.fillScreen(BLACK); //clear M5.Lcd.setCursor(0,0); M5.Lcd.println("M5StickC-IR");//AutoConnectAP //M5.Lcd.setCursor(0,20); //M5.Lcd.println("SSID: "); //M5.Lcd.print(WiFi.SSID()); M5.Lcd.setCursor(0,60); M5.Lcd.println("IP address: "); M5.Lcd.print((String)ipadr[0] + "." + (String)ipadr[1] + "." + (String)ipadr[2] + "." + (String)ipadr[3]); //mDNS设定 if (MDNS.begin("m5c")) { MDNS.addService("http", "tcp", 80); Serial.println("mDNS responder started"); } //WEB服务器设定 webServer.on("/", handleIndex); // root webServer.on("/messages", handleMessages); //messages webServer.on("/ledon", handleLedOn); //LED ON webServer.on("/ledoff" , handleLedOff); //LED OFF webServer.on("/wifireset", handleWiFiReset); //重设wifi webServer.on("/favicon.ico", handleNotFound); //未找到图标 webServer.onNotFound(handleNotFound); webServer.begin(); Serial.println("Web server started"); } void loop() { //右键 if(digitalRead(M5_BUTTON_RST) == LOW){ Serial.println("RST"); digitalWrite(M5_LED, LOW); //LED ON irsend.sendNEC(0x02fd58a7, 32); //TOSHIBA REGZA VOLUME UP 02fd58a7 delay(200); irsend.sendPanasonic(0x4004, 0x0D00818C); //Panasonic DIGA Back 40040D00818C while(digitalRead(M5_BUTTON_RST) == LOW); digitalWrite(M5_LED, HIGH); //LED OFF } //HOME 键 if(digitalRead(M5_BUTTON_HOME) == LOW){ Serial.println("HOME"); digitalWrite(M5_LED, LOW); //LED ON irsend.sendNEC(0x02fd7887, 32); //TOSHIBA REGZA VOL DOWN 02fd7887 delay(200); irsend.sendPanasonic(0x4004, 0x0D00FAF7); //Panasonic DIGA display 40040D00FAF7 while(digitalRead(M5_BUTTON_HOME) == LOW); digitalWrite(M5_LED, HIGH); //LED OFF } //响应客户端请求 webServer.handleClient(); } void handleWiFiReset() { //WiFi reset Serial.println("reset WiFi settings"); webServer.send(200, "text/plain", "reset WiFi settings..."); M5.Lcd.fillScreen(BLACK); M5.Lcd.setTextSize(2); M5.Lcd.setCursor(0,4); M5.Lcd.println("Reset WiFi settings"); WiFi.disconnect(true); // still not erasing the ssid/pw. Will happily reconnect on next start WiFi.begin("0","0"); // adding this effectively seems to erase the previous stored SSID/PW ESP.restart(); delay(1000); }[/mw_shl_code] 文件下载归档.zip |
