4946| 1
[已解决] 关于AGV小车通过蓝牙控制走线的问题 |
int E2 = 5; //定义M1使能端 int E1 = 6; //定义M2使能端 int M2 = 4; //定义M1控制端 int M1 = 7; //定义M2控制端 int H1 = 2; //定义霍尔传感器左1 int H2 = 3; //定义霍尔传感器左2 int H3 = 8; //定义霍尔传感器中 int H4 = 9; //定义霍尔传感器右2 int H5 = 10; //定义霍尔传感器右1 int stateH1; int stateH2; int stateH3; int stateH4; int stateH5; void stop(void) { //停止 digitalWrite(E1, LOW); digitalWrite(E2, LOW); } void advance(char a, char b) { //前进 analogWrite (E1, a); //PWM调速 digitalWrite(M1, HIGH); analogWrite (E2, b); digitalWrite(M2, HIGH); } void back_off (char a, char b) { //后退 analogWrite (E1, a); digitalWrite(M1, LOW); analogWrite (E2, b); digitalWrite(M2, LOW); } void turn_L (char a, char b) { //左转 analogWrite (E1, a); digitalWrite(M1, LOW); analogWrite (E2, b); digitalWrite(M2, HIGH); } void turn_R (char a, char b) { //右转 analogWrite (E1, a); digitalWrite(M1, HIGH); analogWrite (E2, b); digitalWrite(M2, LOW); } void setup() { int i; int move; pinMode (H1, INPUT); pinMode (H2, INPUT); pinMode (H3, INPUT); pinMode (H4, INPUT); pinMode (H5, INPUT); for (i = 3; i <= 10; i++) pinMode(i, OUTPUT); Serial.begin(9600);// put your setup code here, to run once: // wdt_enable(WDTO_120MS);//打开看门狗(防止死机) delay(1000); } void loop() { char val; val = Serial.read(); //读串口 if (val != -1) { switch (val) { case'A': zuozhuan(); break; case'B': youzhuan(); break; case'C': zhixing(); break; case'D': back_off(100, 100); break; default: stop(); break; } // if (val == 'A' ) { // zuozhuan(); // //Serial.print('A'); // } // else if (val == 'B') { // youzhuan(); // // Serial.print("B"); // } // else if (val == 'C') { // zhixing(); // // Serial.print('C'); // } // else { // stop(); // } } } void zuozhuan() { stateH1 = digitalRead (H1); stateH2 = digitalRead (H2); stateH3 = digitalRead (H3); stateH4 = digitalRead (H4); stateH5 = digitalRead (H5); /* Hall Sensor */ if ((stateH1 == LOW && stateH2 == LOW && stateH3 == HIGH && stateH4 == LOW && stateH5 == LOW) || (stateH1 == LOW && stateH2 == HIGH && stateH3 == HIGH && stateH4 == HIGH && stateH5 == LOW) || (stateH1 == HIGH && stateH2 == LOW && stateH3 == LOW && stateH4 == LOW && stateH5 == HIGH) || (stateH1 == LOW && stateH2 == HIGH && stateH3 == LOW && stateH4 == HIGH && stateH5 == LOW)) //前进 { advance(150, 150); } else if (( stateH5 == LOW && stateH4 == LOW && stateH3 == LOW && stateH2 == HIGH && stateH1 == LOW ) || ( stateH5 == LOW && stateH4 == LOW && stateH3 == HIGH && stateH2 == HIGH && stateH1 == LOW)) //偏右转 { advance(150, 155); } else if (( stateH5 == LOW && stateH4 == HIGH && stateH3 == LOW && stateH2 == LOW && stateH1 == LOW ) || ( stateH5 == LOW && stateH4 == HIGH && stateH3 == HIGH && stateH2 == LOW && stateH1 == LOW)) //偏左转 { advance(155, 150); } else if ((stateH5 == HIGH && stateH4 == HIGH && stateH3 == HIGH && stateH2 == LOW && stateH1 == LOW) || ( stateH5 == HIGH && stateH4 == HIGH && stateH3 == LOW && stateH2 == LOW && stateH1 == LOW ) || (stateH5 == HIGH && stateH4 == LOW && stateH3 == HIGH && stateH2 == LOW && stateH1 == LOW) || ( stateH5 == HIGH && stateH4 == LOW && stateH3 == LOW && stateH2 == LOW && stateH1 == LOW) || (stateH5 == HIGH && stateH4 == LOW && stateH3 == LOW && stateH2 == HIGH && stateH1 == LOW) || (stateH5 == HIGH && stateH4 == HIGH && stateH3 == LOW && stateH2 == HIGH && stateH1 == LOW) || (stateH5 == HIGH && stateH4 == HIGH)) //左转 { turn_L(100, 180); //advance(0, 80); delay(600); } else { stop(); } } void youzhuan() { stateH1 = digitalRead (H1); stateH2 = digitalRead (H2); stateH3 = digitalRead (H3); stateH4 = digitalRead (H4); stateH5 = digitalRead (H5); /* Hall Sensor */ if ((stateH1 == LOW && stateH2 == LOW && stateH3 == HIGH && stateH4 == LOW && stateH5 == LOW) || (stateH1 == LOW && stateH2 == HIGH && stateH3 == HIGH && stateH4 == HIGH && stateH5 == LOW) || (stateH1 == HIGH && stateH2 == LOW && stateH3 == LOW && stateH4 == LOW && stateH5 == HIGH) || (stateH1 == LOW && stateH2 == HIGH && stateH3 == LOW && stateH4 == HIGH && stateH5 == LOW)) //前进 { advance(150, 150); } else if (( stateH5 == LOW && stateH4 == LOW && stateH3 == LOW && stateH2 == HIGH && stateH1 == LOW ) || ( stateH5 == LOW && stateH4 == LOW && stateH3 == HIGH && stateH2 == HIGH && stateH1 == LOW)) //偏右转 { advance(150, 155); } else if (( stateH5 == LOW && stateH4 == HIGH && stateH3 == LOW && stateH2 == LOW && stateH1 == LOW ) || ( stateH5 == LOW && stateH4 == HIGH && stateH3 == HIGH && stateH2 == LOW && stateH1 == LOW)) //偏左转 { advance(155, 150); } else if ((stateH5 == LOW && stateH4 == LOW && stateH3 == HIGH && stateH2 == HIGH && stateH1 == HIGH) || (stateH5 == LOW && stateH4 == LOW && stateH3 == LOW && stateH2 == HIGH && stateH1 == HIGH) || (stateH5 == LOW && stateH4 == LOW && stateH3 == HIGH && stateH2 == LOW && stateH1 == HIGH) || (stateH5 == LOW && stateH4 == LOW && stateH3 == LOW && stateH2 == LOW && stateH1 == HIGH) || (stateH5 == LOW && stateH4 == LOW && stateH3 == LOW && stateH2 == HIGH && stateH1 == HIGH) || (stateH5 == LOW && stateH4 == HIGH && stateH3 == LOW && stateH2 == HIGH && stateH1 == HIGH) || (stateH2 == HIGH && stateH1 == HIGH)) //右转 { turn_R(180, 100 ); // advance(80, 0); delay(600); } else { stop(); } } void zhixing() { stateH1 = digitalRead (H1); stateH2 = digitalRead (H2); stateH3 = digitalRead (H3); stateH4 = digitalRead (H4); stateH5 = digitalRead (H5); /* Hall Sensor */ if ((stateH1 == LOW && stateH2 == LOW && stateH3 == HIGH && stateH4 == LOW && stateH5 == LOW) || (stateH1 == LOW && stateH2 == HIGH && stateH3 == HIGH && stateH4 == HIGH && stateH5 == LOW) || (stateH1 == HIGH && stateH2 == LOW && stateH3 == LOW && stateH4 == LOW && stateH5 == HIGH) || (stateH1 == LOW && stateH2 == HIGH && stateH3 == LOW && stateH4 == HIGH && stateH5 == LOW)) //前进 { advance(150, 150); } else if (( stateH5 == LOW && stateH4 == LOW && stateH3 == LOW && stateH2 == HIGH && stateH1 == LOW ) || ( stateH5 == LOW && stateH4 == LOW && stateH3 == HIGH && stateH2 == HIGH && stateH1 == LOW)) //偏右转 { advance(150, 155); } else if (( stateH5 == LOW && stateH4 == HIGH && stateH3 == LOW && stateH2 == LOW && stateH1 == LOW ) || ( stateH5 == LOW && stateH4 == HIGH && stateH3 == HIGH && stateH2 == LOW && stateH1 == LOW)) //偏左转 { advance(155, 150); } else if ((stateH5 == HIGH && stateH4 == HIGH && stateH3 == HIGH && stateH2 == LOW && stateH1 == LOW) || ( stateH5 == HIGH && stateH4 == HIGH && stateH3 == LOW && stateH2 == LOW && stateH1 == LOW ) || (stateH5 == HIGH && stateH4 == LOW && stateH3 == HIGH && stateH2 == LOW && stateH1 == LOW) || ( stateH5 == HIGH && stateH4 == LOW && stateH3 == LOW && stateH2 == LOW && stateH1 == LOW) || (stateH5 == HIGH && stateH4 == LOW && stateH3 == LOW && stateH2 == HIGH && stateH1 == LOW) || (stateH5 == HIGH && stateH4 == HIGH && stateH3 == LOW && stateH2 == HIGH && stateH1 == LOW) || (stateH5 == HIGH && stateH4 == HIGH)) //左转 { turn_L(100, 180); //advance(0, 80); delay(600); } else if ((stateH5 == LOW && stateH4 == LOW && stateH3 == HIGH && stateH2 == HIGH && stateH1 == HIGH) || (stateH5 == LOW && stateH4 == LOW && stateH3 == LOW && stateH2 == HIGH && stateH1 == HIGH) || (stateH5 == LOW && stateH4 == LOW && stateH3 == HIGH && stateH2 == LOW && stateH1 == HIGH) || (stateH5 == LOW && stateH4 == LOW && stateH3 == LOW && stateH2 == LOW && stateH1 == HIGH) || (stateH5 == LOW && stateH4 == LOW && stateH3 == LOW && stateH2 == HIGH && stateH1 == HIGH) || (stateH5 == LOW && stateH4 == HIGH && stateH3 == LOW && stateH2 == HIGH && stateH1 == HIGH) || (stateH2 == HIGH && stateH1 == HIGH)) //右转 { turn_R(180, 100 ); // advance(80, 0); delay(600); } else { stop(); } } 以上为代码,问题是在下位机(AGV小车)接收到A、B、C等符号时,小车虽然运动,但是霍尔传感器仿佛完全无效,像瞎子。请各位大佬求解 |
