请问这是怎么回事
2020-01-025990
本文解决了 Arduino 项目中常见的 'D2' 未声明和 'client' 未声明的报错问题。首先,'D2' 未声明错误通常是由于引脚名称未正确声明或拼写错误引起的。解决方法是检查并修正引脚定义。其次,'client' 未声明错误通常是因为 MQTT 客户端未正确定义和初始化。通过确保所有变量已正确定义和初始化,可以解决这些问题。最终,你的项目将能够顺利连接 WiFi 和 MQTT 服务器,实现无缝通信。
C:\Users\acer\Desktop\sketch_jan02a\sketch_jan02a.ino: In function 'void openLight()':
sketch_jan02a:6: error: 'D2' was not declared in this scope
#define BEDROOD_LIGHT  D2
C:\Users\acer\Desktop\sketch_jan02a\sketch_jan02a.ino:30:16: note: in expansion of macro 'BEDROOD_LIGHT'
   digitalWrite(BEDROOD_LIGHT, HIGH);
C:\Users\acer\Desktop\sketch_jan02a\sketch_jan02a.ino: In function 'void closeLight()':
C:\Users\acer\Desktop\sketch_jan02a\sketch_jan02a.ino:34:16: note: in expansion of macro 'BEDROOD_LIGHT'
   digitalWrite(BEDROOD_LIGHT, LOW);
C:\Users\acer\Desktop\sketch_jan02a\sketch_jan02a.ino: In function 'void connectWiFi()':
C:\Users\acer\Desktop\sketch_jan02a\sketch_jan02a.ino:40:37: warning: invalid conversion from 'const char*' to 'char*' [-fpermissive]
   WiFi.begin(WIFI_SSID,WIFI_PASSWORD);
In file included from C:\Users\acer\Desktop\sketch_jan02a\sketch_jan02a.ino:1:0:
C:\Users\acer\Desktop\Arduino-1.8.3\libraries\WiFi\src/WiFi.h:79:9: note: initializing argument 1 of 'int WiFiClass::begin(char*, const char*)'
     int begin(char* ssid, const char *passphrase);
C:\Users\acer\Desktop\sketch_jan02a\sketch_jan02a.ino: In function 'void callback(char*, byte*, unsigned int)':
sketch_jan02a:74: error: 'client' was not declared in this scope
   client.publish(pubTopic,sendMseg);
C:\Users\acer\Desktop\sketch_jan02a\sketch_jan02a.ino: In function 'void ConnectAliyun()':
sketch_jan02a:78: error: 'client' was not declared in this scope
   while(!client.connected()){
sketch_jan02a:81: error: 'myAliyun' was not declared in this scope
     if(client.connect(myAliyun.client_id,myAliyun.username,myAliyun.password)){
C:\Users\acer\Desktop\sketch_jan02a\sketch_jan02a.ino: In function 'void setup()':
C:\Users\acer\Desktop\sketch_jan02a\sketch_jan02a.ino:94:11: note: in expansion of macro 'BEDROOD_LIGHT'
   pinMode(BEDROOD_LIGHT,OUTPUT);
sketch_jan02a:100: error: 'myAliyun' was not declared in this scope
   myAliyun.init(ALIYUN_SERVER,ProductKey,ClientId,DeviceName,DeviceSecret);
sketch_jan02a:102: error: 'client' was not declared in this scope
   client.setServer(myAliyun.mqtt_server,PORT);
C:\Users\acer\Desktop\sketch_jan02a\sketch_jan02a.ino: In function 'void loop()':
sketch_jan02a:118: error: 'client' was not declared in this scope
   if(!client.connected()){
sketch_jan02a:121: error: 'client' was not declared in this scope
   client.loop();
exit status 1
评论(3)
20060606
20060606
没有添加库
kylinpoet
kylinpoet
这个好,必须支持。
gada888
gada888
代码开头没有添加库文件
