13| 0
[已解决] 怎样布置简易开源飞行控制器 |
""" SimpleDrone - 简易开源飞行控制器 版本: 0.1 硬件要求: - STM32F4/F7系列飞控板 - MPU6050 (加速度计+陀螺仪) - PWM电机驱动 - 2.4GHz接收机 """ import time import math class FlightController: def __init__(self): self.armed = False self.throttle = 0 # 0-100% self.pitch = 0 # -100~100 self.roll = 0 # -100~100 self.yaw = 0 # -100~100 # PID参数 self.pid_pitch = {"P": 0.8, "I": 0.05, "D": 0.2} self.pid_roll = {"P": 0.8, "I": 0.05, "D": 0.2} self.pid_yaw = {"P": 1.0, "I": 0.01, "D": 0.0} # 传感器数据 self.accel = [0, 0, 0] self.gyro = [0, 0, 0] def arm(self): """解锁电机""" if self.safety_check(): self.armed = True self._send_signal("MOTORS_ARMED") def disarm(self): """锁定电机""" self.armed = False self._send_signal("MOTORS_DISARMED") def update_sensors(self, accel, gyro): """更新IMU传感器数据""" self.accel = accel self.gyro = gyro def set_controls(self, throttle, pitch, roll, yaw): """设置遥控输入""" self.throttle = max(0, min(100, throttle)) self.pitch = max(-100, min(100, pitch)) self.roll = max(-100, min(100, roll)) self.yaw = max(-100, min(100, yaw)) def stabilize(self): """飞行姿态稳定控制""" if not self.armed: return # 获取传感器数据 ax, ay, az = self.accel gx, gy, gz = self.gyro # 计算姿态角 (简化版) pitch_angle = math.atan2(ax, math.sqrt(ay**2 + az**2)) roll_angle = math.atan2(ay, math.sqrt(ax**2 + az**2)) # PID计算 (伪代码) pitch_correction = self._calculate_pid(pitch_angle, self.pitch, self.pid_pitch) roll_correction = self._calculate_pid(roll_angle, self.roll, self.pid_roll) yaw_correction = self._calculate_pid(gz, self.yaw, self.pid_yaw) # 电机混控输出 self._mixer_output( throttle=self.throttle, pitch=pitch_correction, roll=roll_correction, yaw=yaw_correction ) def _calculate_pid(self, current, target, pid_params): """简易PID控制器""" # 伪实现 - 实际需要积分/微分计算 error = target - current return error * pid_params["P"] def _mixer_output(self, throttle, pitch, roll, yaw): """四轴X模式混控""" # 电机布局: 前 后 左 右 # [0] [1] # \ / # / \ # [2] [3] m1 = throttle + pitch + roll + yaw m2 = throttle + pitch - roll - yaw m3 = throttle - pitch + roll - yaw m4 = throttle - pitch - roll + yaw self._set_motor_speed(1, m1) self._set_motor_speed(2, m2) self._set_motor_speed(3, m3) self._set_motor_speed(4, m4) def _set_motor_speed(self, motor_id, speed): """设置电机转速 (0-100%)""" # 硬件接口调用 print(f"Motor {motor_id}: {max(0, min(100, speed))}%") def _send_signal(self, command): """发送控制信号 (硬件接口)""" print(f"[SIGNAL] {command}") def safety_check(self): """安全检查 (示例)""" # 实际需检查传感器状态等 return True # ===== 使用示例 ===== if __name__ == "__main__": drone = FlightController() # 模拟传感器更新 drone.update_sensors(accel=[0.1, 0.02, 1.0], gyro=[0.01, -0.02, 0.1]) # 设置控制输入 drone.set_controls(throttle=50, pitch=0, roll=5, yaw=0) # 解锁并稳定 drone.arm() drone.stabilize() time.sleep(1) drone.disarm() https://vk.com/topic-230756849_53738773 https://vk.com/topic-230756849_53738772 https://vk.com/topic-230756849_53738771 https://vk.com/topic-230756849_53738770 https://vk.com/topic-230756849_53738769 https://vk.com/topic-230756849_53738768 https://vk.com/topic-230756849_53738767 https://vk.com/topic-230756849_53738765 https://vk.com/topic-230756849_53738764 https://vk.com/topic-230756849_53738763 https://vk.com/topic-230756849_53738762 https://vk.com/topic-230756849_53738761 https://vk.com/topic-230756849_53738760 https://vk.com/topic-230756849_53738759 https://vk.com/topic-230756849_53738758 https://vk.com/topic-230756849_53738757 https://vk.com/topic-230756849_53738756 https://vk.com/topic-230756849_53738754 https://vk.com/topic-230756849_53738753 https://vk.com/topic-230756849_53738751 https://vk.com/topic-230756849_53738748 https://vk.com/topic-230756849_53738747 https://vk.com/topic-230756849_53738746 https://vk.com/topic-230756849_53738745 https://vk.com/topic-230756849_53738744 https://vk.com/topic-230756849_53738743 https://vk.com/topic-230756849_53738742 https://vk.com/topic-230756849_53738741 https://vk.com/topic-230756849_53738740 https://vk.com/topic-230756849_53738739 https://vk.com/topic-230756849_53738738 https://vk.com/topic-230756849_53738736 https://vk.com/topic-230756849_53738735 https://vk.com/topic-230756849_53738734 https://vk.com/topic-230756849_53738733 https://vk.com/topic-230756849_53738731 https://vk.com/topic-230756849_53738730 https://vk.com/topic-230756849_53738729 https://vk.com/topic-230756849_53738728 https://vk.com/topic-230756849_53738727 https://vk.com/topic-230756849_53738726 https://vk.com/topic-230756849_53738692 https://vk.com/topic-230756849_53738691 https://vk.com/topic-230756849_53738690 https://vk.com/topic-230756849_53738689 https://vk.com/topic-230756849_53738688 https://vk.com/topic-230756849_53738687 https://vk.com/topic-230756849_53738686 https://vk.com/topic-230756849_53738685 https://vk.com/topic-230756849_53738684 https://vk.com/topic-230756849_53738683 https://vk.com/topic-230756849_53738679 https://vk.com/topic-230756849_53738678 https://vk.com/topic-230756849_53738677 https://vk.com/topic-230756849_53738676 https://vk.com/topic-230756849_53738674 https://vk.com/topic-230756849_53738673 https://vk.com/topic-230756849_53738672 https://vk.com/topic-230756849_53738671 https://vk.com/topic-230756849_53738670 https://vk.com/topic-230756849_53738668 https://vk.com/topic-230756849_53738667 https://vk.com/topic-230756849_53738666 https://vk.com/topic-230756849_53738665 https://vk.com/topic-230756849_53738664 https://vk.com/topic-230756849_53738663 https://vk.com/topic-230756849_53738662 https://vk.com/topic-230756849_53738660 https://vk.com/topic-230756849_53738659 https://vk.com/topic-230756849_53738658 https://vk.com/topic-230756849_53738657 https://vk.com/topic-230756849_53738656 https://vk.com/topic-230756849_53738655 https://vk.com/topic-230756849_53738654 https://vk.com/topic-230756849_53738653 https://vk.com/topic-230756849_53738652 https://vk.com/topic-230756849_53738651 https://vk.com/topic-230756849_53738650 https://vk.com/topic-230756849_53738649 https://vk.com/topic-230756849_53738648 https://vk.com/topic-230756849_53738647 https://vk.com/topic-230756849_53738646 https://vk.com/topic-230756849_53738645 https://vk.com/topic-230756849_53738644 https://vk.com/topic-230756849_53738643 https://vk.com/topic-230756849_53738642 https://vk.com/topic-230756849_53738640 https://vk.com/topic-230756849_53738639 https://vk.com/topic-230756849_53738638 https://vk.com/topic-230756849_53738637 https://vk.com/topic-230756849_53738636 https://vk.com/topic-230756849_53738633 https://vk.com/topic-230756849_53738631 https://vk.com/topic-230756849_53738630 https://vk.com/topic-230756849_53738629 https://vk.com/topic-230756849_53738628 https://vk.com/topic-230756849_53738627 https://vk.com/topic-230756849_53738626 https://vk.com/topic-230756849_53738625 https://vk.com/topic-230756849_53738624 https://vk.com/topic-230756849_53738623 https://vk.com/topic-230756849_53738622 https://vk.com/topic-230756849_53738621 https://vk.com/topic-230756849_53738620 https://vk.com/topic-230756849_53738619 https://vk.com/topic-230756849_53738618 https://vk.com/topic-230756849_53738616 https://vk.com/topic-230756849_53738615 https://vk.com/topic-230756849_53738614 https://vk.com/topic-230756849_53738613 https://vk.com/topic-230756849_53738612 https://vk.com/topic-230756849_53738611 https://vk.com/topic-230756849_53738610 https://vk.com/topic-230756849_53738609 https://vk.com/topic-230756849_53738608 https://vk.com/topic-230756849_53738607 https://vk.com/topic-230756849_53738606 https://vk.com/topic-230756849_53738604 https://vk.com/topic-230756849_53738603 https://vk.com/topic-230756849_53738602 https://vk.com/topic-230756849_53738601 https://vk.com/topic-230756849_53738600 https://vk.com/topic-230756849_53738599 https://vk.com/topic-230756849_53738598 https://vk.com/topic-230756849_53738596 https://vk.com/topic-230756849_53738595 https://vk.com/topic-230756849_53738593 https://vk.com/topic-230756849_53738592 https://vk.com/topic-230756849_53738591 https://vk.com/topic-230756849_53738590 https://vk.com/topic-230756849_53738589 https://vk.com/topic-230756849_53738588 https://vk.com/topic-230756849_53738587 https://vk.com/topic-230756849_53738586 https://vk.com/topic-230756849_53738584 https://vk.com/topic-230756849_53738583 https://vk.com/topic-230756849_53738582 https://vk.com/topic-230756849_53738581 https://vk.com/topic-230756849_53738580 https://vk.com/topic-230756849_53738579 https://vk.com/topic-230756849_53738578 https://vk.com/topic-230756849_53738574 https://vk.com/topic-230756849_53738573 https://vk.com/topic-230756849_53738572 https://vk.com/topic-230756849_53738571 https://vk.com/topic-230756849_53738570 https://vk.com/topic-230756849_53738569 https://vk.com/topic-230756849_53738568 https://vk.com/topic-230756849_53738567 https://vk.com/topic-230756849_53738564 https://vk.com/topic-230756849_53738562 https://vk.com/topic-230756849_53738561 https://vk.com/topic-230756849_53738560 https://vk.com/topic-230756849_53738559 https://vk.com/topic-230756849_53738557 https://vk.com/topic-230756849_53738554 https://vk.com/topic-230756849_53738552 https://vk.com/topic-230756849_53738551 https://vk.com/topic-230756849_53738550 https://vk.com/topic-230756849_53738547 https://vk.com/topic-230756849_53738545 https://vk.com/topic-230756849_53738544 https://vk.com/topic-230756849_53738543 https://vk.com/topic-230756849_53738541 https://vk.com/topic-230756849_53738540 https://vk.com/topic-230756849_53738539 https://vk.com/topic-230756849_53738538 https://vk.com/topic-230756849_53738537 https://vk.com/topic-230756849_53738536 https://vk.com/topic-230756849_53738535 https://vk.com/topic-230756849_53738534 https://vk.com/topic-230756849_53738532 https://vk.com/topic-230756849_53738530 https://vk.com/topic-230756849_53738527 https://vk.com/topic-230756849_53738526 https://vk.com/topic-230756849_53738525 https://vk.com/topic-230756849_53738523 https://vk.com/topic-230756849_53738521 https://vk.com/topic-230756849_53738518 https://vk.com/topic-230756849_53738517 https://vk.com/topic-230756849_53738516 https://vk.com/topic-230756849_53738515 https://vk.com/topic-230756849_53738514 https://vk.com/topic-230756849_53738513 https://vk.com/topic-230756849_53738512 https://vk.com/topic-230756849_53738510 https://vk.com/topic-230756849_53738509 https://vk.com/topic-230756849_53738507 https://vk.com/topic-230756849_53738506 https://vk.com/topic-230756849_53738504 https://vk.com/topic-230756849_53738502 https://vk.com/topic-230756849_53738481 https://vk.com/topic-230756849_53738479 https://vk.com/topic-230756849_53738477 https://vk.com/topic-230756849_53738476 https://vk.com/topic-230756849_53738475 https://vk.com/topic-230756849_53738474 https://vk.com/topic-230756849_53738471 https://vk.com/topic-230756849_53738470 https://vk.com/topic-230756849_53738469 https://vk.com/topic-230756849_53738467 https://vk.com/topic-230756849_53738465 https://vk.com/topic-230756849_53738464 https://vk.com/topic-230756849_53738462 https://vk.com/topic-230756849_53738461 https://vk.com/topic-230756849_53738460 https://vk.com/topic-230756849_53738459 https://vk.com/topic-230756849_53738458 https://vk.com/topic-230756849_53738457 https://vk.com/topic-230756849_53738455 https://vk.com/topic-230756849_53738454 https://vk.com/topic-230756849_53738453 https://vk.com/topic-230756849_53738452 https://vk.com/topic-230756849_53738451 https://vk.com/topic-230756849_53738450 https://vk.com/topic-230756849_53738448 https://vk.com/topic-230756849_53738446 https://vk.com/topic-230756849_53738443 https://vk.com/topic-230756849_53738442 https://vk.com/topic-230756849_53738440 https://vk.com/topic-230756849_53738439 https://vk.com/topic-230756849_53738437 https://vk.com/topic-230756849_53738436 https://vk.com/topic-230756849_53738435 https://vk.com/topic-230756849_53738433 https://vk.com/topic-230756849_53738431 https://vk.com/topic-230756849_53738430 https://vk.com/topic-230756849_53738429 https://vk.com/topic-230756849_53738427 https://vk.com/topic-230756849_53738426 https://vk.com/topic-230756849_53738425 https://vk.com/topic-230756849_53738423 https://vk.com/topic-230756849_53738422 https://vk.com/topic-230756849_53738421 https://vk.com/topic-230756849_53738420 https://vk.com/topic-230756849_53738419 https://vk.com/topic-230756849_53738418 https://vk.com/topic-230756849_53738417 https://vk.com/topic-230756849_53738416 https://vk.com/topic-230756849_53738414 https://vk.com/topic-230756849_53738413 https://vk.com/topic-230756849_53738403 https://vk.com/topic-230756849_53738402 https://vk.com/topic-230756849_53738400 https://vk.com/topic-230756849_53738399 https://vk.com/topic-230756849_53738398 https://vk.com/topic-230756849_53738397 https://vk.com/topic-230756849_53738395 https://vk.com/topic-230756849_53738394 https://vk.com/topic-230756849_53738393 https://vk.com/topic-230756849_53738390 https://vk.com/topic-230756849_53738388 https://vk.com/topic-230756849_53738387 https://vk.com/topic-230756849_53738384 https://vk.com/topic-230756849_53738383 https://vk.com/topic-230756849_53738381 https://vk.com/topic-230756849_53738380 https://vk.com/topic-230756849_53738379 https://vk.com/topic-230756849_53738377 https://vk.com/topic-230756849_53738375 https://vk.com/topic-230756849_53738374 https://vk.com/topic-230756849_53738373 https://vk.com/topic-230756849_53738372 https://vk.com/topic-230756849_53738370 https://vk.com/topic-230756849_53738369 https://vk.com/topic-230756849_53738367 https://vk.com/topic-230756849_53738364 https://vk.com/topic-230756849_53738362 https://vk.com/topic-230756849_53738360 https://vk.com/topic-230756849_53738359 https://vk.com/topic-230756849_53738358 https://vk.com/topic-230756849_53738356 https://vk.com/topic-230756849_53738355 https://vk.com/topic-230756849_53738354 https://vk.com/topic-230756849_53738352 https://vk.com/topic-230756849_53738351 https://vk.com/topic-230756849_53738347 https://vk.com/topic-230756849_53738346 https://vk.com/topic-230756849_53738344 https://vk.com/topic-230756849_53738343 https://vk.com/topic-230756849_53738342 https://vk.com/topic-230756849_53738341 https://vk.com/topic-230756849_53738338 https://vk.com/topic-230756849_53738337 https://vk.com/topic-230756849_53738335 https://vk.com/topic-230756849_53738333 https://vk.com/topic-230756849_53738332 https://vk.com/topic-230756849_53738331 https://vk.com/topic-230756849_53738330 https://vk.com/topic-230756849_53738328 https://vk.com/topic-230756849_53738327 https://vk.com/topic-230756849_53738320 https://vk.com/topic-230756849_53738317 https://vk.com/topic-230756849_53738315 https://vk.com/topic-230756849_53738313 https://vk.com/topic-230756849_53738312 https://vk.com/topic-230756849_53738311 https://vk.com/topic-230756849_53738310 https://vk.com/topic-230756849_53738308 https://vk.com/topic-230756849_53738307 https://vk.com/topic-230756849_53738306 https://vk.com/topic-230756849_53738305 https://vk.com/topic-230756849_53738304 https://vk.com/topic-230756849_53738303 https://vk.com/topic-230756849_53738302 https://vk.com/topic-230756849_53738301 https://vk.com/topic-230756849_53738299 https://vk.com/topic-230756849_53738298 https://vk.com/topic-230756849_53738296 https://vk.com/topic-230756849_53738295 https://vk.com/topic-230756849_53738293 https://vk.com/topic-230756849_53738292 https://vk.com/topic-230756849_53738290 https://vk.com/topic-230756849_53738288 https://vk.com/topic-230756849_53738287 https://vk.com/topic-230756849_53738286 https://vk.com/topic-230756849_53738285 https://vk.com/topic-230756849_53738283 https://vk.com/topic-230756849_53738281 https://vk.com/topic-230756849_53738280 https://vk.com/topic-230756849_53738279 https://vk.com/topic-230756849_53738277 https://vk.com/topic-230756849_53738276 https://vk.com/topic-230756849_53738274 https://vk.com/topic-230756849_53738272 https://vk.com/topic-230756849_53738271 https://vk.com/topic-230756849_53738268 https://vk.com/topic-230756849_53738266 https://vk.com/topic-230756849_53738264 https://vk.com/topic-230756849_53738263 https://vk.com/topic-230756849_53738261 https://vk.com/topic-230756849_53738260 https://vk.com/topic-230756849_53738259 https://vk.com/topic-230756849_53738258 https://vk.com/topic-230756849_53738256 https://vk.com/topic-230756849_53738254 https://vk.com/topic-230756849_53738253 https://vk.com/topic-230756849_53738252 https://vk.com/topic-230756849_53738251 https://vk.com/topic-230756849_53738248 https://vk.com/topic-230756849_53738247 https://vk.com/topic-230756849_53738130 https://vk.com/topic-230756849_53738128 https://vk.com/topic-230756849_53738127 https://vk.com/topic-230756849_53738126 https://vk.com/topic-230756849_53738125 https://vk.com/topic-230756849_53738124 https://vk.com/topic-230756849_53738122 https://vk.com/topic-230756849_53738120 https://vk.com/topic-230756849_53738119 https://vk.com/topic-230756849_53738118 https://vk.com/topic-230756849_53738117 https://vk.com/topic-230756849_53738116 https://vk.com/topic-230756849_53738115 https://vk.com/topic-230756849_53738114 https://vk.com/topic-230756849_53738113 https://vk.com/topic-230756849_53738110 https://vk.com/topic-230756849_53738109 https://vk.com/topic-230756849_53738105 https://vk.com/topic-230756849_53738104 https://vk.com/topic-230756849_53738102 https://vk.com/topic-230756849_53738101 https://vk.com/topic-230756849_53738099 https://vk.com/topic-230756849_53738096 https://vk.com/topic-230756849_53738094 https://vk.com/topic-230756849_53738093 https://vk.com/topic-230756849_53738092 https://vk.com/topic-230756849_53738091 https://vk.com/topic-230756849_53738090 https://vk.com/topic-230756849_53738088 https://vk.com/topic-230756849_53738087 https://vk.com/topic-230756849_53738085 https://vk.com/topic-230756849_53738084 https://vk.com/topic-230756849_53738083 https://vk.com/topic-230756849_53738082 https://vk.com/topic-230756849_53738081 https://vk.com/topic-230756849_53738079 https://vk.com/topic-230756849_53738078 https://vk.com/topic-230756849_53738077 https://vk.com/topic-230756849_53738076 https://vk.com/topic-230756849_53738073 https://vk.com/topic-230756849_53738071 https://vk.com/topic-230756849_53738070 https://vk.com/topic-230756849_53738069 https://vk.com/topic-230756849_53738068 https://vk.com/topic-230756849_53738065 https://vk.com/topic-230756849_53738064 https://vk.com/topic-230756849_53738063 https://vk.com/topic-230756849_53738062 https://vk.com/topic-230756849_53738061 https://vk.com/topic-230756849_53738060 https://vk.com/topic-230756849_53737993 https://vk.com/topic-230756849_53737991 https://vk.com/topic-230756849_53737988 https://vk.com/topic-230756849_53737985 https://vk.com/topic-230756849_53737984 https://vk.com/topic-230756849_53737983 https://vk.com/topic-230756849_53737982 https://vk.com/topic-230756849_53737979 https://vk.com/topic-230756849_53737978 https://vk.com/topic-230756849_53737977 https://vk.com/topic-230756849_53737975 https://vk.com/topic-230756849_53737973 https://vk.com/topic-230756849_53737972 https://vk.com/topic-230756849_53737971 https://vk.com/topic-230756849_53737970 https://vk.com/topic-230756849_53737968 https://vk.com/topic-230756849_53737966 https://vk.com/topic-230756849_53737965 https://vk.com/topic-230756849_53737963 https://vk.com/topic-230756849_53737962 https://vk.com/topic-230756849_53737961 https://vk.com/topic-230756849_53737960 https://vk.com/topic-230756849_53737958 https://vk.com/topic-230756849_53737955 https://vk.com/topic-230756849_53737954 https://vk.com/topic-230756849_53737953 https://vk.com/topic-230756849_53737951 https://vk.com/topic-230756849_53737949 https://vk.com/topic-230756849_53737948 https://vk.com/topic-230756849_53737946 https://vk.com/topic-230756849_53737945 https://vk.com/topic-230756849_53737944 https://vk.com/topic-230756849_53737943 https://vk.com/topic-230756849_53737941 https://vk.com/topic-230756849_53737940 https://vk.com/topic-230756849_53737939 https://vk.com/topic-230756849_53737937 https://vk.com/topic-230756849_53737936 https://vk.com/topic-230756849_53737934 https://vk.com/topic-230756849_53737933 https://vk.com/topic-230756849_53737932 https://vk.com/topic-230756849_53737930 https://vk.com/topic-230756849_53737929 https://vk.com/topic-230756849_53737928 https://vk.com/topic-230756849_53737926 https://vk.com/topic-230756849_53737924 https://vk.com/topic-230756849_53737923 https://vk.com/topic-230756849_53737919 https://vk.com/topic-230756849_53737918 https://vk.com/topic-230756849_53737917 https://vk.com/topic-230756849_53737904 https://vk.com/topic-230756849_53737903 https://vk.com/topic-230756849_53737901 https://vk.com/topic-230756849_53737899 https://vk.com/topic-230756849_53737896 https://vk.com/topic-230756849_53737894 https://vk.com/topic-230756849_53737893 https://vk.com/topic-230756849_53737890 https://vk.com/topic-230756849_53737888 https://vk.com/topic-230756849_53737886 https://vk.com/topic-230756849_53737884 https://vk.com/topic-230756849_53737881 https://vk.com/topic-230756849_53737880 https://vk.com/topic-230756849_53737878 https://vk.com/topic-230756849_53737876 https://vk.com/topic-230756849_53737875 https://vk.com/topic-230756849_53737873 https://vk.com/topic-230756849_53737872 https://vk.com/topic-230756849_53737871 https://vk.com/topic-230756849_53737869 https://vk.com/topic-230756849_53737867 https://vk.com/topic-230756849_53737865 https://vk.com/topic-230756849_53737862 https://vk.com/topic-230756849_53737860 https://vk.com/topic-230756849_53737859 https://vk.com/topic-230756849_53737857 https://vk.com/topic-230756849_53737855 https://vk.com/topic-230756849_53737853 https://vk.com/topic-230756849_53737850 https://vk.com/topic-230756849_53737848 https://vk.com/topic-230756849_53737846 https://vk.com/topic-230756849_53737844 https://vk.com/topic-230756849_53737843 https://vk.com/topic-230756849_53737841 https://vk.com/topic-230756849_53737839 https://vk.com/topic-230756849_53737837 https://vk.com/topic-230756849_53737836 https://vk.com/topic-230756849_53737832 https://vk.com/topic-230756849_53737830 https://vk.com/topic-230756849_53737826 https://vk.com/topic-230756849_53737825 https://vk.com/topic-230756849_53737823 https://vk.com/topic-230756849_53737820 https://vk.com/topic-230756849_53737818 https://vk.com/topic-230756849_53737817 https://vk.com/topic-230756849_53737813 https://vk.com/topic-230756849_53737812 https://vk.com/topic-230756849_53737811 https://vk.com/topic-230756849_53737809 https://vk.com/topic-230756849_53737808 https://vk.com/topic-230756849_53737798 https://vk.com/topic-230756849_53737795 https://vk.com/topic-230756849_53737794 https://vk.com/topic-230756849_53737791 https://vk.com/topic-230756849_53737788 https://vk.com/topic-230756849_53737787 https://vk.com/topic-230756849_53737784 https://vk.com/topic-230756849_53737782 https://vk.com/topic-230756849_53737780 https://vk.com/topic-230756849_53737779 https://vk.com/topic-230756849_53737777 https://vk.com/topic-230756849_53737772 https://vk.com/topic-230756849_53737769 https://vk.com/topic-230756849_53737767 https://vk.com/topic-230756849_53737765 https://vk.com/topic-230756849_53737764 https://vk.com/topic-230756849_53737761 https://vk.com/topic-230756849_53737758 https://vk.com/topic-230756849_53737756 https://vk.com/topic-230756849_53737754 https://vk.com/topic-230756849_53737752 https://vk.com/topic-230756849_53737751 https://vk.com/topic-230756849_53737749 https://vk.com/topic-230756849_53737745 https://vk.com/topic-230756849_53737744 https://vk.com/topic-230756849_53737742 https://vk.com/topic-230756849_53737738 https://vk.com/topic-230756849_53737736 https://vk.com/topic-230756849_53737735 https://vk.com/topic-230756849_53737732 https://vk.com/topic-230756849_53737731 https://vk.com/topic-230756849_53737730 https://vk.com/topic-230756849_53737726 https://vk.com/topic-230756849_53737724 https://vk.com/topic-230756849_53737721 https://vk.com/topic-230756849_53737720 https://vk.com/topic-230756849_53737717 https://vk.com/topic-230756849_53737715 https://vk.com/topic-230756849_53737712 https://vk.com/topic-230756849_53737706 https://vk.com/topic-230756849_53737703 https://vk.com/topic-230756849_53737699 https://vk.com/topic-230756849_53737698 https://vk.com/topic-230756849_53737696 https://vk.com/topic-230756849_53737692 https://vk.com/topic-230756849_53737689 https://vk.com/topic-230756849_53737688 https://vk.com/topic-230756849_53737687 https://vk.com/topic-230756849_53737685 https://vk.com/topic-230756849_53737684 https://vk.com/topic-230756849_53737671 https://vk.com/topic-230756849_53737669 https://vk.com/topic-230756849_53737668 https://vk.com/topic-230756849_53737666 https://vk.com/topic-230756849_53737665 https://vk.com/topic-230756849_53737664 https://vk.com/topic-230756849_53737661 https://vk.com/topic-230756849_53737659 https://vk.com/topic-230756849_53737657 https://vk.com/topic-230756849_53737655 https://vk.com/topic-230756849_53737650 https://vk.com/topic-230756849_53737648 https://vk.com/topic-230756849_53737647 https://vk.com/topic-230756849_53737644 https://vk.com/topic-230756849_53737641 https://vk.com/topic-230756849_53737639 https://vk.com/topic-230756849_53737637 https://vk.com/topic-230756849_53737635 https://vk.com/topic-230756849_53737634 https://vk.com/topic-230756849_53737631 https://vk.com/topic-230756849_53737630 https://vk.com/topic-230756849_53737628 https://vk.com/topic-230756849_53737627 https://vk.com/topic-230756849_53737625 https://vk.com/topic-230756849_53737624 https://vk.com/topic-230756849_53737623 https://vk.com/topic-230756849_53737621 https://vk.com/topic-230756849_53737620 https://vk.com/topic-230756849_53737617 https://vk.com/topic-230756849_53737616 https://vk.com/topic-230756849_53737613 https://vk.com/topic-230756849_53737612 https://vk.com/topic-230756849_53737609 https://vk.com/topic-230756849_53737608 https://vk.com/topic-230756849_53737606 https://vk.com/topic-230756849_53737605 https://vk.com/topic-230756849_53737602 https://vk.com/topic-230756849_53737600 https://vk.com/topic-230756849_53737599 https://vk.com/topic-230756849_53737595 https://vk.com/topic-230756849_53737594 https://vk.com/topic-230756849_53737593 https://vk.com/topic-230756849_53737591 https://vk.com/topic-230756849_53737589 https://vk.com/topic-230756849_53737588 https://vk.com/topic-230756849_53737586 https://vk.com/topic-230756849_53737585 https://vk.com/topic-230756849_53737581 https://vk.com/topic-230756849_53737580 https://vk.com/topic-230756849_53737578 https://vk.com/topic-230756849_53737572 https://vk.com/topic-230756849_53737571 https://vk.com/topic-230756849_53737569 https://vk.com/topic-230756849_53737567 https://vk.com/topic-230756849_53737566 https://vk.com/topic-230756849_53737565 https://vk.com/topic-230756849_53737564 https://vk.com/topic-230756849_53737563 https://vk.com/topic-230756849_53737561 https://vk.com/topic-230756849_53737559 https://vk.com/topic-230756849_53737555 https://vk.com/topic-230756849_53737553 https://vk.com/topic-230756849_53737549 https://vk.com/topic-230756849_53737547 https://vk.com/topic-230756849_53737546 https://vk.com/topic-230756849_53737544 https://vk.com/topic-230756849_53737542 https://vk.com/topic-230756849_53737541 https://vk.com/topic-230756849_53737539 https://vk.com/topic-230756849_53737537 https://vk.com/topic-230756849_53737536 https://vk.com/topic-230756849_53737534 https://vk.com/topic-230756849_53737532 https://vk.com/topic-230756849_53737530 https://vk.com/topic-230756849_53737528 https://vk.com/topic-230756849_53737527 https://vk.com/topic-230756849_53737524 https://vk.com/topic-230756849_53737523 https://vk.com/topic-230756849_53737521 https://vk.com/topic-230756849_53737520 https://vk.com/topic-230756849_53737518 https://vk.com/topic-230756849_53737516 https://vk.com/topic-230756849_53737515 https://vk.com/topic-230756849_53737512 https://vk.com/topic-230756849_53737511 https://vk.com/topic-230756849_53737509 https://vk.com/topic-230756849_53737507 https://vk.com/topic-230756849_53737505 https://vk.com/topic-230756849_53737504 https://vk.com/topic-230756849_53737503 https://vk.com/topic-230756849_53737500 https://vk.com/topic-230756849_53737498 https://vk.com/topic-230756849_53737495 https://vk.com/topic-230756849_53737494 https://vk.com/topic-230756849_53737492 https://vk.com/topic-230756849_53737490 https://vk.com/topic-230756849_53737488 https://vk.com/topic-230756849_53737486 https://vk.com/topic-230756849_53737484 https://vk.com/topic-230756849_53737483 https://vk.com/topic-230756849_53737472 https://vk.com/topic-230756849_53737470 https://vk.com/topic-230756849_53737467 https://vk.com/topic-230756849_53737466 https://vk.com/topic-230756849_53737463 https://vk.com/topic-230756849_53737461 https://vk.com/topic-230756849_53737459 https://vk.com/topic-230756849_53737457 https://vk.com/topic-230756849_53737456 https://vk.com/topic-230756849_53737454 https://vk.com/topic-230756849_53737450 https://vk.com/topic-230756849_53737448 https://vk.com/topic-230756849_53737447 https://vk.com/topic-230756849_53737446 https://vk.com/topic-230756849_53737444 https://vk.com/topic-230756849_53737440 https://vk.com/topic-230756849_53737438 https://vk.com/topic-230756849_53737436 https://vk.com/topic-230756849_53737432 https://vk.com/topic-230756849_53737430 https://vk.com/topic-230756849_53737429 https://vk.com/topic-230756849_53737426 https://vk.com/topic-230756849_53737425 https://vk.com/topic-230756849_53737421 https://vk.com/topic-230756849_53737419 https://vk.com/topic-230756849_53737417 https://vk.com/topic-230756849_53737415 https://vk.com/topic-230756849_53737413 https://vk.com/topic-230756849_53737412 https://vk.com/topic-230756849_53737410 https://vk.com/topic-230756849_53737409 https://vk.com/topic-230756849_53737407 https://vk.com/topic-230756849_53737405 https://vk.com/topic-230756849_53737403 https://vk.com/topic-230756849_53737401 https://vk.com/topic-230756849_53737399 https://vk.com/topic-230756849_53737396 https://vk.com/topic-230756849_53737395 https://vk.com/topic-230756849_53737392 https://vk.com/topic-230756849_53737391 https://vk.com/topic-230756849_53737387 https://vk.com/topic-230756849_53737386 https://vk.com/topic-230756849_53737384 https://vk.com/topic-230756849_53737382 https://vk.com/topic-230756849_53737381 https://vk.com/topic-230756849_53737377 https://vk.com/topic-230756849_53737375 https://vk.com/topic-230756849_53737371 https://vk.com/topic-230756849_53737369 https://vk.com/topic-230756849_53737368 |
