566| 1
[求助] 求大佬们帮忙,k10和esp32之间的无线连接问题 |
我想利用FireBeetle 2 ESP32-S3开发板和附带一个OV2640摄像头,以及k10。实现让开发板开启热点,k10无线连接这个热点并实时显示OV2640摄像头的视频。现在esp32的程序已经做好了,但是k10怎么也连不上去。显示不了画面。求大佬们看看哪里出问题了。下面的是esp32的程序。k10的程序做不出来。上传模式里面没有相应的模块。#include "DFRobot_AXP313A.h"DFRobot_AXP313A axp; #include <Arduino.h> #include "esp_camera.h" #include <WiFi.h> #include "board_config.h" const char *ssid = "K10_CAM"; const char *password = "12345678"; WiFiServer server(80); void setup() { while(axp.begin() != 0){ delay(1000); } axp.enableCameraPower(axp.eOV2640); Serial.begin(115200); Serial.setDebugOutput(true); Serial.println(); camera_config_t config; config.ledc_channel = LEDC_CHANNEL_0; config.ledc_timer = LEDC_TIMER_0; config.pin_d0 = Y2_GPIO_NUM; config.pin_d1 = Y3_GPIO_NUM; config.pin_d2 = Y4_GPIO_NUM; config.pin_d3 = Y5_GPIO_NUM; config.pin_d4 = Y6_GPIO_NUM; config.pin_d5 = Y7_GPIO_NUM; config.pin_d6 = Y8_GPIO_NUM; config.pin_d7 = Y9_GPIO_NUM; config.pin_xclk = XCLK_GPIO_NUM; config.pin_pclk = PCLK_GPIO_NUM; config.pin_vsync = VSYNC_GPIO_NUM; config.pin_href = HREF_GPIO_NUM; config.pin_sccb_sda = SIOD_GPIO_NUM; config.pin_sccb_scl = SIOC_GPIO_NUM; config.pin_pwdn = PWDN_GPIO_NUM; config.pin_reset = RESET_GPIO_NUM; config.xclk_freq_hz = 16000000; config.frame_size = FRAMESIZE_QVGA; config.pixel_format = PIXFORMAT_JPEG; config.grab_mode = CAMERA_GRAB_LATEST; config.fb_location = CAMERA_FB_IN_PSRAM; config.jpeg_quality = 15; config.fb_count = 1; esp_err_t err = esp_camera_init(&config); if (err != ESP_OK) { Serial.printf("Camera init failed with error 0x%x", err); return; } sensor_t *s = esp_camera_sensor_get(); // ----------------- 画面方向(已经正确) s->set_vflip(s, 0); s->set_hmirror(s, 0); // ----------------- 解决 波纹 + 偏暗 + 偏绿(通用函数,100%不报错) s->set_brightness(s, 2); // 提亮 s->set_contrast(s, 1); // 对比度 s->set_saturation(s, 1); // 色彩 s->set_awb_gain(s, 1); // 自动白平衡(去绿色) s->set_gain_ctrl(s, 1); // 自动增益 s->set_exposure_ctrl(s, 1);// 自动曝光 s->set_lenc(s, 1); // 去波纹 s->set_bpc(s, 1); // ----------------- WiFi WiFi.softAP(ssid, password); IPAddress apIP = WiFi.softAPIP(); Serial.println("WiFi 热点已开启!"); server.begin(); Serial.print("Camera Ready! Use http://"); Serial.print(apIP); Serial.println(" to connect"); } void loop() { WiFiClient client = server.accept(); if (!client) return; String req = client.readStringUntil('\n'); client.flush(); if (req.indexOf("GET /") >= 0) { client.println("HTTP/1.1 200 OK"); client.println("Content-Type: multipart/x-mixed-replace; boundary=frame"); client.println(); while (client.connected()) { camera_fb_t *fb = esp_camera_fb_get(); if (!fb) break; client.println("--frame"); client.println("Content-Type: image/jpeg"); client.println("Content-Length: " + String(fb->len)); client.println(); client.write(fb->buf, fb->len); client.println(); esp_camera_fb_return(fb); } } client.stop(); } |
