十万火急!SIM7000C接收不到AT指令
2019-06-161.7万
本文介绍了如何解决MEGA2560与SIM7000C模块通信故障的问题。通过检查SIM卡状态和设置波特率,可以确保SIM7000C模块正常接收AT指令。具体步骤包括初始化SIM7000C模块、设置波特率以及检查SIM卡状态。这些方法可以帮助用户快速定位并解决问题,确保项目顺利进行。
10创造力
MEGA2560装配了SIM7000C,采用7.4V锂电池作为外部电源,跑样例代码无响应,SIM7000C的ON灯亮着,NET灯会闪烁,但是得不到数据,一直是"Turn ON SIM7000......",真的很着急,求大佬帮忙!#include <Wire.h>
#include <DFRobot_SIM7000.h>
#define PIN_TX     7
#define PIN_RX     8
SoftwareSerial     mySerial(PIN_RX,PIN_TX);
DFRobot_SIM7000    sim7000;
void setup(){
    int signalStrength,dataNum;
    Serial.begin(115200);
    while(!Serial);
    sim7000.begin(mySerial);
    Serial.println("Enter anything to get positioning ");
    char loge[10];
    readSerial(loge);
    Serial.println("Getting position......");
    Serial.println("Turn ON SIM7000......");
    if(sim7000.turnON()){                                          //Turn ON SIM7000
        Serial.println("Turn ON !");
    Serial.println("Set baud rate......");
    while(1){
        if(sim7000.setBaudRate(19200)){                            //Set SIM7000 baud rate from 115200 to 19200 reduce the baud rate to avoid distortion
            Serial.println("Set baud rate:19200");
            break;
        }else{
            Serial.println("Faile to set baud rate");
            delay(1000);
    Serial.println("Check SIM card......");
    if(sim7000.checkSIMStatus()){                                  //Check SIM card
        Serial.println("SIM card READY");
    }else{
        Serial.println("SIM card ERROR, Check if you h ave insert SIM card and restart SIM7000");
        while(1);
    Serial.println("Init positioning function......");
    while(1){
        if(sim7000.initPos()){
            Serial.println("Positioning function initialized");
            break;
        }else{
            Serial.println("Fail to init positioning function");
            delay(1000);
void loop(){
    Serial.println("Enter anything end with CRLF to get positioning ");
    char loge[10];
    readSerial(loge);
    if(sim7000.getPosition()){                                     //Get the current position
        Serial.print(" Longitude : ");
        Serial.println(sim7000.getLongitude());                    //Get longitude
        Serial.print(" Latitude : ");
        Serial.println(sim7000.getLatitude());                     //Get latitude
    }else{
        Serial.println("Wrong data try again");
int readSerial(char result[]){
    int i = 0;
    while(1){
        while(Serial.available() > 0){
            char inChar = Serial.read();
            if(inChar == '\n'){
                result = '\0';
                Serial.flush();
                return 0;
            if(inChar != '\r'){
                result = inChar;
                i++;
评论(10)
fanxin_bme
我的用的UNO,能跑起来,但到了Getting position的这句后,输入任意内容回车后,显示Wrong data try again.
我用的是手机sim卡,不是NB-iot的卡,是不是不行?
诩
不要只给程序,接线和其他数据也很重要
三春牛-创客
额,我不会啊
KkQ1VrB7W776
检查接线,检查程序,检查硬件
我是小黄
将换行符 改成NL CL
hijack
我原来也是这样的,主要是因为程序里的引脚设置没改。
将D8和D10短接后,将程序中的:
#define PIN_TX 7
#define PIN_RX 8
改为:
#define PIN_TX 7
#define PIN_RX 10
即可,可以试试,希望有帮助~
青出于蓝
看一下接线
gada888
COM打印出来的结果是什么
大圈biubiu
你用的是什么卡啊,楼上说的应该是用mage的话 需要短接D8和D10
DFSH_Faith
麻烦发一下具体的接线图哦
