11348| 2
[求助问答] Mind+自定义用户库编译问题 |
编译时出现如下报错,求解决办法 C:\Program Files (x86)\Mind+\Arduino\arduino-builder\arduino-builder.exe -preprocess -logger=machine -hardware C:\Program Files (x86)\Mind+\Arduino\hardware -tools C:\Program Files (x86)\Mind+\Arduino\arduino-builder -tools C:\Program Files (x86)\Mind+\Arduino\hardware\tools\avr -libraries C:\Users\gu'zhi'qiang\AppData\Local\DFScratch\extensions\罗博创客-ld3320-thirdex\arduinoC\libraries -built-in-libraries C:\Program Files (x86)\Mind+\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10804 -build-path C:\Users\gu'zhi'qiang\AppData\Local\DFScratch\build -warnings=none -build-cache C:\Users\gu'zhi'qiang\AppData\Local\DFScratch\cache -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Mind+\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Mind+\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Mind+\Arduino\hardware\tools\avr -verbose C:\Users\gu'zhi'qiang\AppData\Local\DFScratch\dfrobot\dfrobot.ino C:\Users\gu'zhi'qiang\AppData\Local\DFScratch\dfrobot\dfrobot.ino:1:24: fatal error: asr_ld3320.h: No such file or directory compilation terminated. exit status 1 arduino builer error! |
报错
