8541| 1
[项目] 组建一个最便宜的树莓派(raspberry pi) HIFI |
硬件:树莓派2代(英国产,512M内存),2704 USB DAC解码器一个,OBJECTIVE2 HEADPHONE AMPLIFIER耳放一台,森海塞尔HD202入门耳机一个(已经用了5年多了) 软件: Volumio 1.1beta for raspberry pi 测试:用树莓派接USB U盘、播放NAS上的音乐(有轻微爆音现象,后找到了解决方法)、接移动硬盘播放都没问题,效果好于PC----》+USB DAC-------》O2耳-----》HD202耳机。 NAS播放轻微爆音问题的解决: Fixes for common USB DAC problems with RPi Postby petli » Tue Jan 07, 2014 9:50 pm I've done a fair bit of digging to get smooth sound out of my USB-driven Cambridge Audio DacMagic, so here's the info for your benefit. It also seems to apply to other USB DACs too. Pops and crackle in the sound can often be fixed by adding dwc_otg.fiq_split_enable=0 to /boot/cmdline.txt. Just add it to the line that doesn't start with a # and reboot. Verify that the parameter took effect by looking for "dwc_otg: FIQ split fix disabled" in the kernel boot log. 拔下SD 卡,插入windows 系统下的电脑,找到卡上根目录下的cmdline.txt文件,打开并编辑这个文件:在第二行开头加上 dwc_otg.fiq_split_enable=0 然后保存文件然后把卡插入树莓派重启树莓派,再播放NAS里的文件时,爆音完全消失啦。。。。。 又是树莓派、USB DAC、3.5寸Harddisk、台面上堆着太乱,吃完饭看到春节家人买甲鱼剩下的塑料包装盒,来,咱们也DIY个小HIFI CASE.......Z再申请个专利名:“龚老汉HIFI 派”。。。。。 |
