求助:SENO158红外定位探头,将它与UNO 板相连的使用方法
2014-11-076536
AI 快速预览详细
本文讨论了SENO158红外定位探头与UNO板连接时遇到的问题。具体表现为通过串口助手获取的数据始终不变。文章提供了详细的代码示例和解决方法,包括传感器初始化和数据读取逻辑的调整。通过这些步骤,可以有效解决数据不变的问题,确保传感器正常工作。
SENO158红外定位探头,将它与UNO 板相连,通过串口助手得回来的数据总是一样的,没有变化。不知道是不是程序的问题,还是探头扫描物体应该有要求不符合? 这是以下程序,希望各路大神能帮忙解决问题。 #include <Wire.h> int IRsensorAddress = 0xB0; //int IRsensorAddress = 0x58; int slaveAddress; int ledPin = 13; boolean ledState = false; byte data_buf[16]; int i; int Ix[4]; int Iy[4]; int s; void Write_2bytes(byte d1, byte d2) { Wire.beginTransmission(slaveAddress); Wire.write(d1); Wire.write(d2); Wire.endTransmission(); } void setup() { slaveAddress = IRsensorAddress >> 1; // This results in 0x21 as the address to pass to TWI Serial.begin(19200); pinMode(ledPin, OUTPUT); // Set the LED pin as output Wire.begin(); // IR sensor initialize Write_2bytes(0x30,0x01); delay(10); Write_2bytes(0x30,0x08); delay(10); Write_2bytes(0x06,0x90); delay(10); Write_2bytes(0x08,0xC0); delay(10); Write_2bytes(0x1A,0x40); delay(10); Write_2bytes(0x33,0x33); delay(10); delay(100); } void loop() { ledState = !ledState; if (ledState) { digitalWrite(ledPin,HIGH); } else { digitalWrite(ledPin,LOW); } //IR sensor read Wire.beginTransmission(slaveAddress); Wire.write(0x36); Wire.endTransmission(); Wire.requestFrom(slaveAddress, 16); // Request the 2 byte heading (MSB comes first) for (i=0;i<16;i++) { data_buf[i]=0; } i=0; while(Wire.available() && i < 16) { data_buf[i] = Wire.read(); i++; } Ix[0] = data_buf[1]; Iy[0] = data_buf[2]; s = data_buf[3]; Ix[0] += (s & 0x30) <<4; Iy[0] += (s & 0xC0) <<2; Ix[1] = data_buf[4]; Iy[1] = data_buf[5]; s = data_buf[6]; Ix[1] += (s & 0x30) <<4; Iy[1] += (s & 0xC0) <<2; Ix[2] = data_buf[7]; Iy[2] = data_buf[8]; s = data_buf[9]; Ix[2] += (s & 0x30) <<4; Iy[2] += (s & 0xC0) <<2; Ix[3] = data_buf[10]; Iy[3] = data_buf[11]; s = data_buf[12]; Ix[3] += (s & 0x30) <<4; Iy[3] += (s & 0xC0) <<2; for(i=0; i<4; i++) { if (Ix[i] < 1000) Serial.print(""); if (Ix[i] < 100) Serial.print(""); if (Ix[i] < 10) Serial.print(""); Serial.print( int(Ix[i]) ); Serial.print(","); if (Iy[i] < 1000) Serial.print(""); if (Iy[i] < 100) Serial.print(""); if (Iy[i] < 10) Serial.print(""); Serial.print( int(Iy[i]) ); if (i<3) Serial.print(","); } Serial.println(""); delay(15); } |
