2026-4-2 22:36:29 [显示全部楼层]
1083浏览
查看: 1083|回复: 1
[ESP8266/ESP32] 求助dfplayermini模块只有通电时有闪一下红灯不放音乐
用的是esp32-cam,dfplayermini模块只有刚通电时亮了下红灯,后面都没亮过,喇叭有滋滋声
这是代码
#ifndef MP3_PLAYER_H
#define MP3_PLAYER_H
#include "esp32cam_config.h"
#include <HardwareSerial.h>
#include <DFRobotDFPlayerMini.h>
// 串口和对象定义
HardwareSerial Mp3Serial(2);
DFRobotDFPlayerMini myDFPlayer;
// 状态变量
bool mp3Initialized = false;
unsigned long lastMP3Heartbeat = 0;
int mp3FailCount = 0;
// 初始化MP3
bool mp3Init() {
  Serial.println("======== MP3初始化 ========");
  Serial.println("引脚: RX=12, TX=16");
  Mp3Serial.end();
  delay(100);
  Mp3Serial.begin(9600, SERIAL_8N1, MP3_RX, MP3_TX);
  delay(300);
  Serial.println("尝试连接DFPlayer...");
  if (myDFPlayer.begin(Mp3Serial, true, true)) {
    delay(200);
    myDFPlayer.volume(25);
    myDFPlayer.stop();
    mp3Initialized = true;
    Serial.println("✓ MP3初始化成功!");
    Serial.println("音量已设为: 25");
    return true;
  Serial.println("✗ MP3初始化失败");
  Serial.println("请检查:接线/电源/SD卡");
  return false;
// 播放音频
void playAudio(uint8_t num) {
  if (!mp3Initialized) {
    Serial.println("MP3未初始化,无法播放");
    return;
  Serial.print("播放音频 #");
  Serial.println(num);
  myDFPlayer.playMp3Folder(num);
// 停止播放
void stopAudio() {
  if (mp3Initialized) {
    Serial.println("停止播放");
    myDFPlayer.stop();
// 设置音量 (0-30)
void setMP3Volume(int volume) {
    volume = constrain(volume, 0, 30);
    myDFPlayer.volume(volume);
    Serial.print("音量设为: ");
    Serial.println(volume);
// 打印状态
void printMP3Status() {
  Serial.println("=== MP3状态 ===");
  Serial.print("初始化: ");
  Serial.println(mp3Initialized ? "是" : "否");
    Serial.print("音量: ");
    Serial.println(myDFPlayer.readVolume());
// 健康检查
void mp3HealthMonitor() {
  static unsigned long lastCheck = 0;
    static unsigned long lastTry = 0;
    if (millis() - lastTry > 10000) {
      lastTry = millis();
      mp3Init();
    return;
  if (millis() - lastCheck > 30000) {
    lastCheck = millis();
    int vol = myDFPlayer.readVolume();
    delay(20);
    if (vol == 0 && myDFPlayer.available()) {
      mp3FailCount++;
      if (mp3FailCount >= 3) {
        Serial.println("MP3心跳失败,尝试重连");
    } else {
      mp3FailCount = 0;
// 兼容性函数
void mp3Heartbeat() {
  mp3HealthMonitor();
#endif
DFEDU  初级技匠
发表于 2026-4-7 18:38:46
建议先用UNO板子单独测试这个dfplayermini模块
